소개
Removing the air filter is really simple. It only takes one one screw to be removed and the rest can be done with your hands. The air filter should be replaced annually.
필요한 것
Use a Flathead #4 screw driver to remove the 40mm screw that holds the air filter case in place.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 2개
Good information, although it didn't resolve my issue. Thanks for sharing
This is a power wash motor water will not come out
