주요 콘텐츠로 건너뛰기
Briggs and Stratton 675 Series Repair Muffler Replacement
필요한 것
  1. Briggs and Stratton 675 Series Repair Muffler Replacement, Muffler: 1 단계, 이미지 1/1
    • Make sure the engine is off and the spark plug wire is removed and away from the spark plug before beginning.
    • Use a socket wrench with a 1/4" hex bit or a 1/4" wrench to remove the three 13mm screws holding the outer flange.
    • Remove the flange.
  2. Briggs and Stratton 675 Series Repair Muffler Replacement: 2 단계, 이미지 1/1
    • Use a pair of needle nose pliers to bend back the two metal tabs on either side of the remaining screws.
    • Be careful not to break off the tabs.
  3. Briggs and Stratton 675 Series Repair Muffler Replacement: 3 단계, 이미지 1/1
    • Use a socket wrench with a 7/16" hex bit or 7/16" wrench to remove the two remaining 75mm screws.
    • Make sure not to lose the metal bar linking the two screws.
  4. Briggs and Stratton 675 Series Repair Muffler Replacement: 4 단계, 이미지 1/2 Briggs and Stratton 675 Series Repair Muffler Replacement: 4 단계, 이미지 2/2
    • Remove the muffler from the engine block by simply pulling it away.
    • After removing the muffler, make sure to note the configuration of the washer assembly that sits between the muffler and the engine block (shown in photo 2). This piece will be free to fall out once the muffler is removed. Do not lose this piece.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Brad Wash
회원 가입일: 02/02/15
476 평판
안내서 2개 작성하였습니다
Cal Poly, Team 6-31, Amido Winter 2015 Cal Poly, Team 6-31, Amido Winter 2015 회원
CPSU-AMIDO-W15S6G31
4 회원들
안내서 14개 작성하였습니다
댓글 한 개
When I removed the muffler from the engine block by simply pulling it away, the thermic regulator fell out and I don't see how/where to fix it again.
Thanks for any help !!!
yvessr - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 57
30일 전: 179
전체 시간: 13,173
