소개
Follow these steps to remove the muffler from your Briggs and Stratton 675 engine. Once removed, a damaged muffler can be replaced or a dirty one cleaned. The muffler can become dirty or damaged over time. It is important to keep it clear of debris so that the exhaust coming from the engine can flow normally.
필요한 것
Use a socket wrench with a 1/4" hex bit or a 1/4" wrench to remove the three 13mm screws holding the outer flange.
Remove the flange.
다른 한 분이 해당 안내서를 완성하였습니다.
