주요 콘텐츠로 건너뛰기
Briggs and Stratton 675 Series Spark Plug Replacement
필요한 것
  1. Briggs and Stratton 675 Series Spark Plug Replacement, Cap Removal: 1 단계, 이미지 2개 중 1개 Briggs and Stratton 675 Series Spark Plug Replacement, Cap Removal: 1 단계, 이미지 2개 중 2개
    • Make sure the engine is turned off before beginning.
    • Use your hands to remove the spark plug wire. It should pop off easily with little effort
  2. Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: 2 단계, 이미지 3개 중 1개 Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: 2 단계, 이미지 3개 중 2개 Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: 2 단계, 이미지 3개 중 3개
    • Use a socket wrench with a 13/16" hex bit to unscrew the spark plug from the engine. You will probably need to use a long hex bit in order to get to the bolt.
    • Pull the spark plug out of its housing with your hands.
    • Alternatively, you may use a wrench or pliers to remove the spark plug instead. (Shown in the second image.)
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Andrew Saunders
회원 가입일: 02/01/15
1,056 평판
안내서 2개를 작성함
Cal Poly, Team 6-31, Amido Winter 2015 Cal Poly, Team 6-31, Amido Winter 2015 회원
CPSU-AMIDO-W15S6G31
4 회원들
안내서 19개를 작성함
14가이드 댓글
I have a Briggs and Stratton engine on my lawn mower but can't get at the spark plug as there is some kind of black plastic housing in front of it.
penora - 답글
Any ideas I have a Briggs and Stratton engine on my lawn mower but can't get at the spark plug as there is some kind of black plastic housing in front of it.
penora - 답글
pinch the front of black cap and pull off
tracy.mullen - 답글
What size spark plug does this 675 series lawn mower take, I didn't see it listed?
Eris - 답글
just remove the plug and take it with you
when buying a new plug
Bill -
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 134
전체 시간: 51,616
