주요 콘텐츠로 건너뛰기
Brightsign 4k Motherboard Removal
필요한 것
  1. Brightsign 4k Motherboard Removal, Outer Shell: 1 단계, 이미지 1/3 Brightsign 4k Motherboard Removal, Outer Shell: 1 단계, 이미지 2/3 Brightsign 4k Motherboard Removal, Outer Shell: 1 단계, 이미지 3/3
    • Remove three 8mm screws from the left side of the device.
    • Remove four 8mm screws from the right side of the device.
  2. Brightsign 4k Motherboard Removal: 2 단계, 이미지 1/3 Brightsign 4k Motherboard Removal: 2 단계, 이미지 2/3 Brightsign 4k Motherboard Removal: 2 단계, 이미지 3/3
    • Apply pressure on the SD card to pop it out of the port.
    • Remove the card by pulling it out.
  3. Brightsign 4k Motherboard Removal: 3 단계, 이미지 1/3 Brightsign 4k Motherboard Removal: 3 단계, 이미지 2/3 Brightsign 4k Motherboard Removal: 3 단계, 이미지 3/3
    • Press down on the top cover of the device and slid it towards you until you see a slight gap created.
    • Lift the top cover off.
  4. Brightsign 4k Motherboard Removal: 4 단계, 이미지 1/3 Brightsign 4k Motherboard Removal: 4 단계, 이미지 2/3 Brightsign 4k Motherboard Removal: 4 단계, 이미지 3/3
    • Slide the body case back away from the bottom.
    • Pull up the body case to remove it from the bottom.
  5. Brightsign 4k Motherboard Removal, Motherboard Removal: 5 단계, 이미지 1/2 Brightsign 4k Motherboard Removal, Motherboard Removal: 5 단계, 이미지 2/2
    • Remove the four 8mm screws at each corner of the motherboard with a JIS #0 screwdriver.
  6. Brightsign 4k Motherboard Removal: 6 단계, 이미지 1/2 Brightsign 4k Motherboard Removal: 6 단계, 이미지 2/2
    • Lift the motherboard out of the casing.
결론
Zackery
회원 가입일: 02/15/18
347 평판
안내서 2개 작성하였습니다
USF Tampa, Team S17-G6, Boczar Spring 2018 USF Tampa, Team S17-G6, Boczar Spring 2018 회원
USFT-BOCZAR-S18S17G6
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 10
전체 시간: 292
