주요 콘텐츠로 건너뛰기
Broan-Nutone NU230BL Filter and Light Replacement
필요한 것
  1. Broan-Nutone NU230BL Filter and Light Replacement, Filter and Light: 1 단계, 이미지 1/1
    • Make sure the fan switch is centered, and the light switch is set to "off" to avoid any injuries.
  2. Broan-Nutone NU230BL Filter and Light Replacement: 2 단계, 이미지 1/1
    • Squeeze both ends of the bulb cover to pop it out of the slots.
  3. Broan-Nutone NU230BL Filter and Light Replacement: 3 단계, 이미지 1/2 Broan-Nutone NU230BL Filter and Light Replacement: 3 단계, 이미지 2/2
    • Make sure the lightbulb is cool before handling to avoid burns.
    • Unscrew and remove the lightbulb by turning it counterclockwise.
  4. Broan-Nutone NU230BL Filter and Light Replacement: 4 단계, 이미지 1/3 Broan-Nutone NU230BL Filter and Light Replacement: 4 단계, 이미지 2/3 Broan-Nutone NU230BL Filter and Light Replacement: 4 단계, 이미지 3/3
    • Twist the latch above the filter clockwise.
    • Slide the filter out by gently pulling it.
  5. Broan-Nutone NU230BL Filter and Light Replacement: 5 단계, 이미지 1/3 Broan-Nutone NU230BL Filter and Light Replacement: 5 단계, 이미지 2/3 Broan-Nutone NU230BL Filter and Light Replacement: 5 단계, 이미지 3/3
    • Insert the new filter.
    • Rotate the retaining latch counterclockwise to secure the filter.
  6. Broan-Nutone NU230BL Filter and Light Replacement: 6 단계, 이미지 1/2 Broan-Nutone NU230BL Filter and Light Replacement: 6 단계, 이미지 2/2
    • Install the new lightbulb and turn it clockwise.
  7. Broan-Nutone NU230BL Filter and Light Replacement: 7 단계, 이미지 1/2 Broan-Nutone NU230BL Filter and Light Replacement: 7 단계, 이미지 2/2
    • Reinsert the lightbulb cover by pressing both sides and fitting the cover's tabs into the slots.
결론
Your range hood is good-to-go!
다른 한 분이 해당 안내서를 완성하였습니다.
Mahdi M
회원 가입일: 01/17/22
169 평판
안내서 1개 작성함
York University, Team P-21, O'Regan Winter 2022 York University, Team P-21, O'Regan Winter 2022 회원
YORK-O'REGAN-W22SPG21
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 12
30일 전: 29
전체 시간: 804
