주요 콘텐츠로 건너뛰기
Broil-King BBQ Heat Indicator Replacement Guide
필요한 것
  1. Broil-King BBQ Heat Indicator Replacement Guide, Heat Indicator: 1 단계, 이미지 1/3 Broil-King BBQ Heat Indicator Replacement Guide, Heat Indicator: 1 단계, 이미지 2/3 Broil-King BBQ Heat Indicator Replacement Guide, Heat Indicator: 1 단계, 이미지 3/3
    • Gather the tools and parts needed for the repair:
    • Crescent Wrench
    • Scraper
    • Replacement Heat Indicator
    • Be sure that the grill is completely cool and disconnect any gas tanks before beginning the repair.
  2. Broil-King BBQ Heat Indicator Replacement Guide: 2 단계, 이미지 1/2 Broil-King BBQ Heat Indicator Replacement Guide: 2 단계, 이미지 2/2
    • Open the lid and then remove the nut securing the heat indicator.
    • Use a crescent wrench to loosen the nut.
    • Continue to unthread the nut with your fingers.
    • Place the nut in a secure location for later use.
  3. Broil-King BBQ Heat Indicator Replacement Guide: 3 단계, 이미지 1/2 Broil-King BBQ Heat Indicator Replacement Guide: 3 단계, 이미지 2/2
    • Close the lid.
    • Slide the flat edge of the paint scraper under the existing heat indicator plate to pry the plate loose.
    • Lift the plate up, then off of the predrilled holes.
  4. Broil-King BBQ Heat Indicator Replacement Guide: 4 단계, 이미지 1/3 Broil-King BBQ Heat Indicator Replacement Guide: 4 단계, 이미지 2/3 Broil-King BBQ Heat Indicator Replacement Guide: 4 단계, 이미지 3/3
    • Push the heat indicator from the back to remove it from the Broilmate plate.
  5. Broil-King BBQ Heat Indicator Replacement Guide: 5 단계, 이미지 1/3 Broil-King BBQ Heat Indicator Replacement Guide: 5 단계, 이미지 2/3 Broil-King BBQ Heat Indicator Replacement Guide: 5 단계, 이미지 3/3
    • Align the new heat indicator through the front of the plate.
    • Move your thumbs around the plate until the heat indicator is secure.
  6. Broil-King BBQ Heat Indicator Replacement Guide: 6 단계, 이미지 1/3 Broil-King BBQ Heat Indicator Replacement Guide: 6 단계, 이미지 2/3 Broil-King BBQ Heat Indicator Replacement Guide: 6 단계, 이미지 3/3
    • Align the new heat indicator and plate with the factory drilled holes on the face of the BBQ.
    • Hold the plate in place while opening the lid.
  7. Broil-King BBQ Heat Indicator Replacement Guide: 7 단계, 이미지 1/2 Broil-King BBQ Heat Indicator Replacement Guide: 7 단계, 이미지 2/2
    • Retrieve the nut used on the previous heat indicator (remember you put it in a secure location).
    • Thread the nut on the new heat indicator.
    • Use a crescent wrench to finish tightening the nut on the new bolt.
  8. Broil-King BBQ Heat Indicator Replacement Guide: 8 단계, 이미지 1/1
    • Close the lid. You're done!
결론
This simple repair doesn’t take much time, yet is well worth the effort. A working heat indicator provides the necessary information about the temperature to ensure safe food practices, and produce a tasty outcome.
다른 2명이 해당 안내서를 완성하였습니다.
Jamie Jacaway
회원 가입일: 06/11/21
172 평판
안내서 1개 작성함
Idaho State University, Team S1-G10, Watkins Summer 2021 Idaho State University, Team S1-G10, Watkins Summer 2021 회원
ISU-WATKINS-SU21S1G10
2 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 37
전체 시간: 758
