주요 콘텐츠로 건너뛰기
Broken Zipper On Luggage Replacement
필요한 것
  1. Broken Zipper On Luggage Replacement, Zipper: 1 단계, 이미지 1/1
    • Remove the metal stopper at the end with the pliers (which ever set works for your size zipper), using a bit of pressure to pry it off of the slider. This will help the current, broken zipper come off easier.
  2. Broken Zipper On Luggage Replacement: 2 단계, 이미지 1/1
    • Dismantle the current, broken zipper on the slider. To do this, you'll need to use pliers. Apply pressure vertically to pry the zipper away from the teeth of the slider.
    • Use the other pair of pliers to keep the zipper in place while you remove it. It should then smoothly slide off of the slider.
  3. Broken Zipper On Luggage Replacement: 3 단계, 이미지 1/1
    • Install the new zipper. To do this, simply slide the new zipper over the end of the slider chain in the same direction than the old one. This should secure the teeth together for a comfortable fit.
  4. Broken Zipper On Luggage Replacement: 4 단계, 이미지 1/1
    • Applying pressure, use pliers to reattach the metal zipper stopper.
  5. Broken Zipper On Luggage Replacement: 5 단계, 이미지 1/1
    • Secure the new zipper, using the pliers, setting the stoppers back in place and molding it back together.
결론
Mold and bend the stopper, using the pliers, to set the stopper back in place.
다른 4명이 해당 안내서를 완성하였습니다.
Ashley Cooper
회원 가입일: 01/19/18
220 평판
안내서 1개 작성함
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 회원
USFSM-STEWART-S18S1G1
15 회원들
안내서 26개 작성하였습니다
댓글 4개
Thank you. I am about to try this. A few suggestions— you say we need a screwdriver but don’t actually describe using it. It would helpful to identify the three parts of the zipper— the pull , the slider train and the stop—right at the beginning, and be consistent throughout.
aurora - 답글
Thanks for trying to help but you seem to miss out all the critical (difficult) steps. I have read the guide and still have no better idea of what to do.
Simon Bird - 답글
what is a slider chain?
Janet Angelo - 답글
These recommendations are completely incomprehensible. I recommend a visit to the Zipper Rescue website.
David Hammel - 답글
댓글 쓰기
조회 통계:
24 시간 전: 150
7일 전: 987
30일 전: 4,452
전체 시간: 134,025
