주요 콘텐츠로 건너뛰기
Brookstone Big Blue Party/360 Speaker Battery Replacement
필요한 것
  1. Brookstone Big Blue Party/360 Speaker Battery Replacement, Battery description: 1 단계, 이미지 1/2 Brookstone Big Blue Party/360 Speaker Battery Replacement, Battery description: 1 단계, 이미지 2/2
    • The battery used in these speakers is 11.1V 4400 mAh Lithium Ion 3S2P 18650 battery pack. It consists of 6 cells total. The battery pack is protected by an internal PCB board. You can build your own, but I highly recommend purchasing a pre-assembled pack made with high quality brand name cells. Here is one.
    • The original Big Blue Party connector is 2 pin JST-XH 2.54mm 2P. There are many places where you can obtain one. You can even get it on eBay with attached wire leads. Pay attention to the wire polarity! Many vendors sell these connectors with wires attached in reverse from Big Blue battery. You can always reuse your old one though.
    • The original Big Blue Party connector can be attached by simply soldering the wire leads to the battery wire lead. Once again, pay attention to the polarity!
    • The Big Blue Party 360 connector is 3 pin JST-XH 2.54mm 3P. There are many places where you can obtain one. You can even get it on eBay with attached wire leads. Pay attention to the wire polarity! Many vendors sell these connectors with wires attached in reverse from Big Blue battery. You can always reuse your old one though.
    • The Big Blue Party 360 connector is much more complicated. You will need 10K NTC thermistor in order to make it work like the original battery. The recommended one is an axial mount type. Once again, these are carried by many vendors, here is one of many. You will need to attach the connector to the battery pack as follows (see attached diagram):
    • Positive (red) wire on the connector will connect directly to the positive (red) wire on the battery pack.
    • Middle (white) wire on the connector will connect to the one side (doesn't matter which one) of the NTC thermistor. Other side of the thermistor, will connect to the negative (black) wire on the battery pack.
    • Negative (black) wire on the connector will connect directly to the negative (black) wire on the battery pack.
  2. Brookstone Big Blue Party/360 Speaker Battery Replacement, Tools: 2 단계, 이미지 1/1
    • Come prepared
  3. Brookstone Big Blue Party/360 Speaker Battery Replacement, Remove screw covers: 3 단계, 이미지 1/3 Brookstone Big Blue Party/360 Speaker Battery Replacement, Remove screw covers: 3 단계, 이미지 2/3 Brookstone Big Blue Party/360 Speaker Battery Replacement, Remove screw covers: 3 단계, 이미지 3/3
    • Use a thin flat screwdriver to pry these out.
  4. Brookstone Big Blue Party/360 Speaker Battery Replacement, Remove 8 screws from the bottom cover: 4 단계, 이미지 1/2 Brookstone Big Blue Party/360 Speaker Battery Replacement, Remove 8 screws from the bottom cover: 4 단계, 이미지 2/2
    • Remove the screws.
    • Pull the cover off
  5. Brookstone Big Blue Party/360 Speaker Battery Replacement, Remove old battery: 5 단계, 이미지 1/3 Brookstone Big Blue Party/360 Speaker Battery Replacement, Remove old battery: 5 단계, 이미지 2/3 Brookstone Big Blue Party/360 Speaker Battery Replacement, Remove old battery: 5 단계, 이미지 3/3
    • Pull off the tape
    • Remove the battery
    • Use small pliers to unplug battery connector from the circuit board.
    • Carefully guide the wire out from under the circuit board.
  6. Brookstone Big Blue Party/360 Speaker Battery Replacement, Optional - Big Blue 360 Update: 6 단계, 이미지 1/3 Brookstone Big Blue Party/360 Speaker Battery Replacement, Optional - Big Blue 360 Update: 6 단계, 이미지 2/3 Brookstone Big Blue Party/360 Speaker Battery Replacement, Optional - Big Blue 360 Update: 6 단계, 이미지 3/3
    • 360 has a connector that may prove more difficult to remove
    • Remove circuit board by removing 5 phillips screws.
    • Pull the circuit board back.
    • The connector is glued in place (Why????). I used a thin flat screwdriver blade to carefully scrape the glue off. But you may have to hit it with a heat gun if it doesn't loosen up.
    • Note, that this connector has three prongs. You will need to get a battery specifically made for Big Blue 360.
  7. Brookstone Big Blue Party/360 Speaker Battery Replacement, Install new battery: 7 단계, 이미지 1/3 Brookstone Big Blue Party/360 Speaker Battery Replacement, Install new battery: 7 단계, 이미지 2/3 Brookstone Big Blue Party/360 Speaker Battery Replacement, Install new battery: 7 단계, 이미지 3/3
    • Insert new battery into compartment
    • Use electrical tape to hold it down
    • Guide the wire under the circuit board to the connector
    • Connect new battery to the circuit board.
  8. Brookstone Big Blue Party/360 Speaker Battery Replacement, Install the cover: 8 단계, 이미지 1/2 Brookstone Big Blue Party/360 Speaker Battery Replacement, Install the cover: 8 단계, 이미지 2/2
    • Install the bottom cover
    • Secure with the screws
    • Put the rubber plugs back in
    • Turn the speaker on to test it
  9. Brookstone Big Blue Party/360 Speaker Battery Replacement, Optional - further tear down: 9 단계, 이미지 1/2 Brookstone Big Blue Party/360 Speaker Battery Replacement, Optional - further tear down: 9 단계, 이미지 2/2
    • Complete steps 1 - 4
    • Remove the power button bezel by prying it off with a small flat head screwdriver
  10. Brookstone Big Blue Party/360 Speaker Battery Replacement, Connector panel removal: 10 단계, 이미지 1/3 Brookstone Big Blue Party/360 Speaker Battery Replacement, Connector panel removal: 10 단계, 이미지 2/3 Brookstone Big Blue Party/360 Speaker Battery Replacement, Connector panel removal: 10 단계, 이미지 3/3
    • Remove 6 screw covers from connector panel. Note that 2 covers in the center are longer than those in the corners.
    • Remove 6 screws holding the connector panel with a small phillips screwdriver.
    • Remove the cover.
  11. Brookstone Big Blue Party/360 Speaker Battery Replacement, Remove the grill: 11 단계, 이미지 1/3 Brookstone Big Blue Party/360 Speaker Battery Replacement, Remove the grill: 11 단계, 이미지 2/3 Brookstone Big Blue Party/360 Speaker Battery Replacement, Remove the grill: 11 단계, 이미지 3/3
    • There is a wire soldered to the grill on the bottom. You will need to cut or desolder that wire in order to remove the grill
    • Slide the grill off
    • Wear it on you head
  12. Brookstone Big Blue Party/360 Speaker Battery Replacement, Remove woofer membrane: 12 단계, 이미지 1/2 Brookstone Big Blue Party/360 Speaker Battery Replacement, Remove woofer membrane: 12 단계, 이미지 2/2
    • Remove 6 phillips screws holding the membrane
    • Pop it out
  13. Brookstone Big Blue Party/360 Speaker Battery Replacement, Remove the subwoofer: 13 단계, 이미지 1/3 Brookstone Big Blue Party/360 Speaker Battery Replacement, Remove the subwoofer: 13 단계, 이미지 2/3 Brookstone Big Blue Party/360 Speaker Battery Replacement, Remove the subwoofer: 13 단계, 이미지 3/3
    • Remove 4 phillips screws holding the subwoofer in place.
    • Push it out from the back.
    • Unplug it from the amplifier board.
  14. Brookstone Big Blue Party/360 Speaker Battery Replacement, Removing tweeter (optional): 14 단계, 이미지 1/2 Brookstone Big Blue Party/360 Speaker Battery Replacement, Removing tweeter (optional): 14 단계, 이미지 2/2
    • 4 tweeters are all wired together and soldered to the amplifier board. You will need to cut or desolder the wire if you need to remove them.
    • Remove 4 phillips screws holding the speaker in place.
    • Remove the speaker.
    • Note that the speaker mount has cutouts to provide screw clearance. So they go in only one way.
    • You can continue the tear down on your own from here. Rest of the screws are exposed and easily accessible.
    • When putting the grill back on, you will need to solder the wire that was disconnected during dissassembly back on.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Alex P
회원 가입일: 04/26/17
665 평판
안내서 2개 작성하였습니다
댓글 15개
The AC plug cover came off on my big blue party. Is it possible to reattach it?
I tried to do it from the outside without disassembling it but no luck.
Thomas Ellengold - 답글
Thanks for posting this—does anybody know if the Big Blue 360 Party Speaker recall is going to have any further developments regarding the battery overheating issue? Does anybody know if simply replacing the battery will fix the issue or if it’s something in the motherboard itself? Of course they went out of business earlier this year so I’m doubting they’ll actually follow up on it, but would love to keep this product if possible.
Jonathan Alstad - 답글
Update the guide with battery description and connector information. Hopefully this is enough to point you to the right direction.
Alex P -
I replaced the battery on the Big Blue Party and got a new charger but it still won't power on. The red light won't even start or flash. Any ideas?
rendz72 - 답글
Where can I buy charger in Philippines
Ernesto Urmeneta - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 39
전체 시간: 25,943
