주요 콘텐츠로 건너뛰기
Brother Boutique 761 Needle Replacement
필요한 것
  1. Brother Boutique 761 Needle Replacement, Needle: 1 단계, 이미지 2개 중 1개 Brother Boutique 761 Needle Replacement, Needle: 1 단계, 이미지 2개 중 2개
    • Locate the screw and turn the screw counterclockwise (left).
    • Loosen the screw gently and carefully remove the needle.
  2. Brother Boutique 761 Needle Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the faulty needle and replace it with a new needle.
  3. Brother Boutique 761 Needle Replacement: 3 단계, 이미지 1개 중 1개
    • Take the new needle, place the needle carefully at the base of the opening.
    • Secure the new needle, locate the screw and turn it clockwise (right) until tightened.
  4. Brother Boutique 761 Needle Replacement: 4 단계, 이미지 2개 중 1개 Brother Boutique 761 Needle Replacement: 4 단계, 이미지 2개 중 2개
    • Secure the needle once again. We will start to re-thread the sewing machine.
    • Place the thread on the lever with the loose piece of thread on the outside.
  5. Brother Boutique 761 Needle Replacement: 5 단계, 이미지 1개 중 1개
    • Take the loose piece of thread and place it through the hood that is present at the top of the sewing machine.
  6. Brother Boutique 761 Needle Replacement: 6 단계, 이미지 1개 중 1개
    • Pull the thread down towards you in the open on the front of your machine.
    • Hook the thread at the end of the opening.
  7. Brother Boutique 761 Needle Replacement: 7 단계, 이미지 1개 중 1개
    • Take your thread and locate the hole that is in the needle.
    • Put the thread through the hole.
  8. Brother Boutique 761 Needle Replacement: 8 단계, 이미지 1개 중 1개
    • Make sure that the thread is through the needle. Pull the thread down underneath the presser foot.
    • You have now finished replacing the needle and rethreading the sewing machine.
결론
In conclusion, fixing a needle on a sewing machine is a fundamental skill for any person using a sewing machine. By following a few simple steps, you can ensure that the needle is securely and correctly positioned, leading to smooth and accurate stitching.
작성자
2다른 기여자 명과 함께
Erin Juarez
회원 가입일: 10/23/23
157 평판
안내서 1개를 작성함
Sam Houston State, Team 1-6, Bennett Fall 2023 Sam Houston State, Team 1-6, Bennett Fall 2023 회원
SHSU-BENNETT-F23S1G6
2 회원들
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 22
전체 시간: 330
