주요 콘텐츠로 건너뛰기
Brother CS6000i Sewing Light Replacement
필요한 것
  1. Brother CS6000i Sewing Light Replacement, Body: 1 단계, 이미지 2개 중 1개 Brother CS6000i Sewing Light Replacement, Body: 1 단계, 이미지 2개 중 2개
    • Remove the five 20 mm Phillips #2 screws on the back of the device.
    • Remove the single 28 mm Phillips #2 screw on the back of the device.
    • Remove the single 23 mm Phillips #2 screw on the back of the device.
  2. Brother CS6000i Sewing Light Replacement: 2 단계, 이미지 2개 중 1개 Brother CS6000i Sewing Light Replacement: 2 단계, 이미지 2개 중 2개
    • Pull the white cover off.
  3. Brother CS6000i Sewing Light Replacement: 3 단계, 이미지 2개 중 1개 Brother CS6000i Sewing Light Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the final screw, a 11 mm Phillips #2.
    • After removing all eight screws, you will have five 2 mm screws, one 28 mm screw, one 23 mm screw, and one 11 mm screw, all of which are Phillips #2.
  4. Brother CS6000i Sewing Light Replacement: 4 단계, 이미지 3개 중 1개 Brother CS6000i Sewing Light Replacement: 4 단계, 이미지 3개 중 2개 Brother CS6000i Sewing Light Replacement: 4 단계, 이미지 3개 중 3개
    • Slightly pull apart the two halves of the machine, taking care not to strain the attached cables.
    • Unhook the white wires that are connected to the motherboard.
    • Fully separate the two halves.
  5. Brother CS6000i Sewing Light Replacement, Sewing Light: 5 단계, 이미지 1개 중 1개
    • Use a Phillips #2 screwdriver to remove the single 16 mm Phillips #2 screw.
    • Remove the metal plate.
  6. Brother CS6000i Sewing Light Replacement: 6 단계, 이미지 1개 중 1개
    • Use a Phillips #2 screwdriver to remove the two 16 mm Phillips #2 screws.
    • Remove the metal plate underneath screws once screws are removed.
  7. Brother CS6000i Sewing Light Replacement: 7 단계, 이미지 1개 중 1개
    • Use a standoff tip to remove the 10 mm Phillips #2 screw directly next to the lightbulb.
  8. Brother CS6000i Sewing Light Replacement: 8 단계, 이미지 1개 중 1개
    • Disconnect the light connector from the PCB.
  9. Brother CS6000i Sewing Light Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the light.
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
작성자
3다른 기여자 명과 함께
Aidan Lear
회원 가입일: 10/31/24
130 평판
안내서 1개를 작성함
Cuesta, Team 20-1, Krynen Fall 2024 Cuesta, Team 20-1, Krynen Fall 2024 회원
CUESTA-KRYNEN-F24S20G1
5 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 13
전체 시간: 221
