주요 콘텐츠로 건너뛰기
Brother DCP-L2550DW Toner Cartridge Replacement
필요한 것
  1. Brother DCP-L2550DW Toner Cartridge Replacement, Toner Cartridge: 1 단계, 이미지 2개 중 1개 Brother DCP-L2550DW Toner Cartridge Replacement, Toner Cartridge: 1 단계, 이미지 2개 중 2개
    • Unplug your printer from the outlet. Identify your printer and the toner cartridge required.
    • The printer recommends only two cartridges, TN-730 and TN-760.
  2. Brother DCP-L2550DW Toner Cartridge Replacement: 2 단계, 이미지 3개 중 1개 Brother DCP-L2550DW Toner Cartridge Replacement: 2 단계, 이미지 3개 중 2개 Brother DCP-L2550DW Toner Cartridge Replacement: 2 단계, 이미지 3개 중 3개
    • Pull on the tab to open the front plate of your printer.
  3. Brother DCP-L2550DW Toner Cartridge Replacement: 3 단계, 이미지 3개 중 1개 Brother DCP-L2550DW Toner Cartridge Replacement: 3 단계, 이미지 3개 중 2개 Brother DCP-L2550DW Toner Cartridge Replacement: 3 단계, 이미지 3개 중 3개
    • Pull on the green handle to remove the drum unit of your printer.
  4. Brother DCP-L2550DW Toner Cartridge Replacement: 4 단계, 이미지 3개 중 1개 Brother DCP-L2550DW Toner Cartridge Replacement: 4 단계, 이미지 3개 중 2개 Brother DCP-L2550DW Toner Cartridge Replacement: 4 단계, 이미지 3개 중 3개
    • Place the drum unit on a clean flat surface.
    • Press down on the green button at the bottom left corner of the drum unit to unlock the toner cartridge.
    • Remove the toner cartridge from the drum unit.
  5. Brother DCP-L2550DW Toner Cartridge Replacement: 5 단계, 이미지 3개 중 1개 Brother DCP-L2550DW Toner Cartridge Replacement: 5 단계, 이미지 3개 중 2개 Brother DCP-L2550DW Toner Cartridge Replacement: 5 단계, 이미지 3개 중 3개
    • Insert the new toner cartridge into the drum unit by placing it on top of the drum unit and pressing it down, ensuring it is in the locked position.
    • Do not touch the ink roll of the cartridge. It can compromise the quality of the ink.
  6. Brother DCP-L2550DW Toner Cartridge Replacement: 6 단계, 이미지 3개 중 1개 Brother DCP-L2550DW Toner Cartridge Replacement: 6 단계, 이미지 3개 중 2개 Brother DCP-L2550DW Toner Cartridge Replacement: 6 단계, 이미지 3개 중 3개
    • Insert the drum unit back into the printer by placing it at the edge of the opening and sliding it inside until it locks in place.
  7. Brother DCP-L2550DW Toner Cartridge Replacement: 7 단계, 이미지 3개 중 1개 Brother DCP-L2550DW Toner Cartridge Replacement: 7 단계, 이미지 3개 중 2개 Brother DCP-L2550DW Toner Cartridge Replacement: 7 단계, 이미지 3개 중 3개
    • Close the front plate and ensure it is in the locked position.
  8. Brother DCP-L2550DW Toner Cartridge Replacement: 8 단계, 이미지 1개 중 1개
    • Replacement completed. Plug the printer back in the outlet and test it out. You can now use your printer.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Syed Momin Raza
회원 가입일: 01/09/24
157 평판
안내서 1개를 작성함
1가이드 댓글
Hi , I’m facing unable to print double sided issue. It able to print on 1 page, but when the paper roll back and ready to print on the other page, it stuck. Could you help me on this?
Shininimi Here - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 68
전체 시간: 851
