주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
This repair guide shows how to install a new toner cartridge.
도구
지정된 도구가 없습니다.
부품
  1. Press the front cover release button.
    • Press the front cover release button.
    • Keep the button pressed and pull the cover toward yourself.
  2. With the front cover in the downward position, the drum & toner unit will be visible. Grab the black-and-yellow handle on the unit. Lift unit up and pull it out of the printer. Grab the black-and-yellow handle on the unit. Lift unit up and pull it out of the printer.
    • With the front cover in the downward position, the drum & toner unit will be visible.
    • Grab the black-and-yellow handle on the unit. Lift unit up and pull it out of the printer.
  3. Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
    Nintendo Switch 키트 쇼핑하기
    Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
  4. The drum unit is the gray bottom half of the component in the picture, while the top black part is the toner cartridge. Separate the toner cartridge from the drum unit by pressing down on the blue tab and gently lifting the toner cartridge up by the lift on the handle. DO NOT TOUCH the roller bar on the toner cartridge, or the roller bar on the drum unit as illustrated in the pictures.  This may cause a decrease in print quality.
    • The drum unit is the gray bottom half of the component in the picture, while the top black part is the toner cartridge.
    • Separate the toner cartridge from the drum unit by pressing down on the blue tab and gently lifting the toner cartridge up by the lift on the handle.
    • DO NOT TOUCH the roller bar on the toner cartridge, or the roller bar on the drum unit as illustrated in the pictures. This may cause a decrease in print quality.
  5. Insert the toner cartridge into the new drum break by firmly sliding the cartridge into the drum unit. If installed correctly, the blue lever will be locked in a lifted position. Be sure that the black nob located on the back of the toner cartridge is places inside the track located on the drum unit. The third picture illustrates an incorrectly installed drum unit and toner cartridge, notice how the blue lever is down.
    • Insert the toner cartridge into the new drum break by firmly sliding the cartridge into the drum unit. If installed correctly, the blue lever will be locked in a lifted position.
    • Be sure that the black nob located on the back of the toner cartridge is places inside the track located on the drum unit.
    • The third picture illustrates an incorrectly installed drum unit and toner cartridge, notice how the blue lever is down.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Tyler Davies
회원 가입일: 2010년 01월 25일
73 평판
안내서 1개 작성함
Cal Poly, Team 4-14, Forte Winter 2010 Cal Poly, Team 4-14, Forte Winter 2010 회원
CPSU-FORTE-W10S4G14
5 회원들
안내서 5개 작성하였습니다
thanku for this useful information on how to replace toner cartridges for Brother HL-5240...its clear with the images used....most helpful indeed!!!
can also log on to http://www.tonertree.com for some exciting products!!!!
syed - 답글
Thank you for this article! I helped me a lot! I have bought this model of toner http://hardware.nl/printkop/brother/ph11... but when I tried to replace it I failed. Now I did it and my printer work like a new one. Thank you one more time!
Scott Waschlerner - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 11,219
