주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Brother HL-L2400D Drum Replacement
    1. Brother HL-L2400D Drum Replacement, Drum: 1 단계, 이미지 2개 중 1개 Brother HL-L2400D Drum Replacement, Drum: 1 단계, 이미지 2개 중 2개
      • Open the front cover of the printer.
      • Turn off the printer and let it cool down for 10 minutes.
      댓글 쓰기
    2. Brother HL-L2400D Drum Replacement: 2 단계, 이미지 2개 중 1개 Brother HL-L2400D Drum Replacement: 2 단계, 이미지 2개 중 2개
      • Grab the green tab and pull the part out.
      댓글 쓰기
    3. Brother HL-L2400D Drum Replacement: 3 단계, 이미지 3개 중 1개 Brother HL-L2400D Drum Replacement: 3 단계, 이미지 3개 중 2개 Brother HL-L2400D Drum Replacement: 3 단계, 이미지 3개 중 3개
      • Place the drum onto a sheet of paper.
      • Press the green tab on the side to pop out the inside component.
      댓글 쓰기
    4. Brother HL-L2400D Drum Replacement: 4 단계, 이미지 2개 중 1개 Brother HL-L2400D Drum Replacement: 4 단계, 이미지 2개 중 2개
      • Press the green tab firmly until you hear a noise.
      • Pull out the drum using the closest grey part to you.
      댓글 쓰기
    5. Brother HL-L2400D Drum Replacement: 5 단계, 이미지 3개 중 1개 Brother HL-L2400D Drum Replacement: 5 단계, 이미지 3개 중 2개 Brother HL-L2400D Drum Replacement: 5 단계, 이미지 3개 중 3개
      • Place your new replacement drum inside.
      • Press the new drum firmly.
      • The green tab must look like the second and third images to tell that it is properly inserted.
      댓글 쓰기
    6. Brother HL-L2400D Drum Replacement: 6 단계, 이미지 3개 중 1개 Brother HL-L2400D Drum Replacement: 6 단계, 이미지 3개 중 2개 Brother HL-L2400D Drum Replacement: 6 단계, 이미지 3개 중 3개
      • To clean the imaging of the drum, use the slider above.
      • Make sure to go back and forth with the slider several times.
      댓글 쓰기
    7. Brother HL-L2400D Drum Replacement: 7 단계, 이미지 2개 중 1개 Brother HL-L2400D Drum Replacement: 7 단계, 이미지 2개 중 2개
      • Place your replaced part back into the printer.
      • Press and hold the "Go" button at the bottom of the printer.
      • Let go once all four of the button's LEDs are lit up.
      댓글 쓰기
결론
You have successfully replaced the drum! Contact a local recycling centre or a specialized recycling service for instructions on properly disposing of the cartridge or drum unit.
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Micheal Hbeishi
회원 가입일: 01/12/25
305 평판
안내서 1개를 작성함
York University, Team 2-11, Woodhouse Spring 2025 York University, Team 2-11, Woodhouse Spring 2025 회원
YORK-WOODHOUSE-S25S2G11
1 회원
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 53
전체 시간: 627
