주요 콘텐츠로 건너뛰기
Brother IntelliFax-2840 Control Panel Replacement
필요한 것
  1. Brother IntelliFax-2840 Control Panel Replacement, Automatic Document Feeder: 1 단계, 이미지 1개 중 1개
    • Remove the two 15 mm Phillips #1 screws securing the ADF at the rear of the fax machine.
  2. Brother IntelliFax-2840 Control Panel Replacement: 2 단계, 이미지 2개 중 1개 Brother IntelliFax-2840 Control Panel Replacement: 2 단계, 이미지 2개 중 2개
    • Gently pull the ADF up and away from the machine.
  3. Brother IntelliFax-2840 Control Panel Replacement, Control Panel: 3 단계, 이미지 2개 중 1개 Brother IntelliFax-2840 Control Panel Replacement, Control Panel: 3 단계, 이미지 2개 중 2개
    • Gently lift up the control panel.
  4. Brother IntelliFax-2840 Control Panel Replacement: 4 단계, 이미지 3개 중 1개 Brother IntelliFax-2840 Control Panel Replacement: 4 단계, 이미지 3개 중 2개 Brother IntelliFax-2840 Control Panel Replacement: 4 단계, 이미지 3개 중 3개
    • Use a finger or prying tool to gently pop off the right side control arm (furthest from the handset).
    • Repeat for the left side control arm.
    • You can make this task easier by taking the handset out of the cradle and setting it aside.
  5. Brother IntelliFax-2840 Control Panel Replacement: 5 단계, 이미지 2개 중 1개 Brother IntelliFax-2840 Control Panel Replacement: 5 단계, 이미지 2개 중 2개
    • Do not attempt to completely remove the control panel yet, as it is still connected by a cable.
    • Lifting from the front edge, gently flip up the control panel.
  6. Brother IntelliFax-2840 Control Panel Replacement: 6 단계, 이미지 1개 중 1개
    • While supporting the control panel with one hand, remove the three 12.2 mm Phillips #1 screws securing the rear control panel cover.
  7. Brother IntelliFax-2840 Control Panel Replacement: 7 단계, 이미지 1개 중 1개
    • While still supporting the control panel, use your fingers or a spudger to gently free the two plastic clips securing the rear control panel cover.
    • Slide the rear control panel cover down slightly to free it from the three clips along the upper edge.
  8. Brother IntelliFax-2840 Control Panel Replacement: 8 단계, 이미지 2개 중 1개 Brother IntelliFax-2840 Control Panel Replacement: 8 단계, 이미지 2개 중 2개
    • Separate the rear control panel cover from the control panel.
  9. Brother IntelliFax-2840 Control Panel Replacement: 9 단계, 이미지 2개 중 1개 Brother IntelliFax-2840 Control Panel Replacement: 9 단계, 이미지 2개 중 2개
    • Gently pull the control panel cable straight out from its connector.
    • The control panel should now come free.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Geoff Wacker
회원 가입일: 09/30/13
92,056 평판
안내서 89개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 10
전체 시간: 4,449
