주요 콘텐츠로 건너뛰기
Brother MFC 7240 Toner Cartridge Replacement
필요한 것
  1. Brother MFC 7240 Toner Cartridge Replacement, Toner Cartridge: 1 단계, 이미지 3개 중 1개 Brother MFC 7240 Toner Cartridge Replacement, Toner Cartridge: 1 단계, 이미지 3개 중 2개 Brother MFC 7240 Toner Cartridge Replacement, Toner Cartridge: 1 단계, 이미지 3개 중 3개
    • Ensure the printer is on a stable surface with enough room to access the ink cartridge compartment.
    • Turn off the printer by unplugging it from the outlet.
  2. Brother MFC 7240 Toner Cartridge Replacement: 2 단계, 이미지 2개 중 1개 Brother MFC 7240 Toner Cartridge Replacement: 2 단계, 이미지 2개 중 2개
    • Lift the printer cover which is located at the front of the printer to reveal the toner cartridge compartment.
  3. Brother MFC 7240 Toner Cartridge Replacement: 3 단계, 이미지 1개 중 1개
    • Locate the empty ink cartridge that needs replacement.
  4. Brother MFC 7240 Toner Cartridge Replacement: 4 단계, 이미지 3개 중 1개 Brother MFC 7240 Toner Cartridge Replacement: 4 단계, 이미지 3개 중 2개 Brother MFC 7240 Toner Cartridge Replacement: 4 단계, 이미지 3개 중 3개
    • Put your fingers under the slot underneath the toner cartridge and gently pull it out.
  5. Brother MFC 7240 Toner Cartridge Replacement: 5 단계, 이미지 3개 중 1개 Brother MFC 7240 Toner Cartridge Replacement: 5 단계, 이미지 3개 중 2개 Brother MFC 7240 Toner Cartridge Replacement: 5 단계, 이미지 3개 중 3개
    • Press down on the small green lever on the bottom left of the drum unit to release the cartridge.
    • You will need to push down the green lever and pull out the toner cartridge at the same time.
  6. Brother MFC 7240 Toner Cartridge Replacement: 6 단계, 이미지 3개 중 1개 Brother MFC 7240 Toner Cartridge Replacement: 6 단계, 이미지 3개 중 2개 Brother MFC 7240 Toner Cartridge Replacement: 6 단계, 이미지 3개 중 3개
    • Unpack the new toner cartridge.
  7. Brother MFC 7240 Toner Cartridge Replacement: 7 단계, 이미지 3개 중 1개 Brother MFC 7240 Toner Cartridge Replacement: 7 단계, 이미지 3개 중 2개 Brother MFC 7240 Toner Cartridge Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the orange protective casing on the new toner cartridge.
    • Be careful with this step because the protective casing holds the ink so when removing it don't touch the ink roller underneath it or else you will get ink on your fingers.
  8. Brother MFC 7240 Toner Cartridge Replacement: 8 단계, 이미지 3개 중 1개 Brother MFC 7240 Toner Cartridge Replacement: 8 단계, 이미지 3개 중 2개 Brother MFC 7240 Toner Cartridge Replacement: 8 단계, 이미지 3개 중 3개
    • Slide the new cartridge into the drum unit slot until it clicks into place.
    • Ensure you can see the Brother logo on top.
  9. Brother MFC 7240 Toner Cartridge Replacement: 9 단계, 이미지 3개 중 1개 Brother MFC 7240 Toner Cartridge Replacement: 9 단계, 이미지 3개 중 2개 Brother MFC 7240 Toner Cartridge Replacement: 9 단계, 이미지 3개 중 3개
    • Place the cartridge and drum unit into the printer and close the cover.
  10. Brother MFC 7240 Toner Cartridge Replacement: 10 단계, 이미지 3개 중 1개 Brother MFC 7240 Toner Cartridge Replacement: 10 단계, 이미지 3개 중 2개 Brother MFC 7240 Toner Cartridge Replacement: 10 단계, 이미지 3개 중 3개
    • Turn on the printer by plugging it back in.
    • Make sure you don’t get the low toner cartridge message.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Gurnoor Loee
회원 가입일: 01/15/24
181 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 17
전체 시간: 218
