주요 콘텐츠로 건너뛰기
Brother MFC-490CW Front Panel Replacement
필요한 것
  1. Brother MFC-490CW Front Panel Replacement, Remove screws holding the front panel: 1 단계, 이미지 1개 중 1개
    • Use a Phillips #2 screwdriver to remove the three 12.1 mm screws holding the control panel in place.
  2. Brother MFC-490CW Front Panel Replacement, Unplug the panel from the rest of the printer: 2 단계, 이미지 3개 중 1개 Brother MFC-490CW Front Panel Replacement, Unplug the panel from the rest of the printer: 2 단계, 이미지 3개 중 2개 Brother MFC-490CW Front Panel Replacement, Unplug the panel from the rest of the printer: 2 단계, 이미지 3개 중 3개
    • Lift up the front panel from the device.
    • Gently lift up and disconnect the data cables that attach the panel to the printer.
결론
To reassemble the front panel, follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Matt
회원 가입일: 10/30/14
64 평판
안내서 2개를 작성함
UMass Dartmouth, Team 4-4, Miles Fall 2014 UMass Dartmouth, Team 4-4, Miles Fall 2014 회원
UMASSD-MILES-F14S4G4
3 회원들
안내서 11개를 작성함
1가이드 댓글
Be sure the three plastic tabs on the bottom of the black front cover are inserted fully when you snap the cover back into place or else you will get a message saying the ink door is not closed.
Raymond Rinaldi - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 45
전체 시간: 2,042
