주요 콘텐츠로 건너뛰기
Brother MFC-490CW Scanning Glass Replacement
필요한 것
  1. Brother MFC-490CW Scanning Glass Replacement, Removing Scanner Header: 1 단계, 이미지 3개 중 1개 Brother MFC-490CW Scanning Glass Replacement, Removing Scanner Header: 1 단계, 이미지 3개 중 2개 Brother MFC-490CW Scanning Glass Replacement, Removing Scanner Header: 1 단계, 이미지 3개 중 3개
    • Twist green section to allow the scanner head to have a full range of motion.
  2. Brother MFC-490CW Scanning Glass Replacement, Removing Scan Header: 2 단계, 이미지 3개 중 1개 Brother MFC-490CW Scanning Glass Replacement, Removing Scan Header: 2 단계, 이미지 3개 중 2개 Brother MFC-490CW Scanning Glass Replacement, Removing Scan Header: 2 단계, 이미지 3개 중 3개
    • To remove scanner head, open it halfway as possible and slide the hinges out of place and the head will be removed.
  3. Brother MFC-490CW Scanning Glass Replacement, Remove scanner head connection to printer: 3 단계, 이미지 3개 중 1개 Brother MFC-490CW Scanning Glass Replacement, Remove scanner head connection to printer: 3 단계, 이미지 3개 중 2개 Brother MFC-490CW Scanning Glass Replacement, Remove scanner head connection to printer: 3 단계, 이미지 3개 중 3개
    • The panels to expose the cords will become exposed when the head is removed.
    • Pull all colored cords from the printer and unscrew the other wire to be fully removed.
    • Pull the black tab from the printer to remove.
  4. Brother MFC-490CW Scanning Glass Replacement, Removing the bottom screws: 4 단계, 이미지 2개 중 1개 Brother MFC-490CW Scanning Glass Replacement, Removing the bottom screws: 4 단계, 이미지 2개 중 2개
    • Once scanner is free from the printer remove all the screws on the bottom base
    • Use a #2 Philips head screw driver to remove the two 12.1mm screws.
  5. Brother MFC-490CW Scanning Glass Replacement, Exposing scanner glass: 5 단계, 이미지 3개 중 1개 Brother MFC-490CW Scanning Glass Replacement, Exposing scanner glass: 5 단계, 이미지 3개 중 2개 Brother MFC-490CW Scanning Glass Replacement, Exposing scanner glass: 5 단계, 이미지 3개 중 3개
    • To separate the base from the glass hold upright and separate along the edge where you removed the screws.
    • Use hands to expose the glass.
    • Keep track flat once glass is removed as to not lose little parts.
  6. Brother MFC-490CW Scanning Glass Replacement, Replacing scanner glass: 6 단계, 이미지 3개 중 1개 Brother MFC-490CW Scanning Glass Replacement, Replacing scanner glass: 6 단계, 이미지 3개 중 2개 Brother MFC-490CW Scanning Glass Replacement, Replacing scanner glass: 6 단계, 이미지 3개 중 3개
    • Disconnect the glass from the tracks.
    • Remove old or broken glass.
    • Replace with adhesive tape along the bottom of the header and reassemble.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
George Kielpinski
회원 가입일: 10/30/14
50 평판
안내서 1개를 작성함
UMass Dartmouth, Team 4-4, Miles Fall 2014 UMass Dartmouth, Team 4-4, Miles Fall 2014 회원
UMASSD-MILES-F14S4G4
3 회원들
안내서 11개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 14
지난 30일: 50
전체 시간: 5,180
