주요 콘텐츠로 건너뛰기
Brother MFC-490CW Wireless module Replacement
필요한 것
  1. Brother MFC-490CW Wireless module Replacement, Remove screws holding the front panel: 1 단계, 이미지 1개 중 1개
    • Use a Phillips #2 screwdriver to remove the three 12.1 mm screws holding the control panel in place.
  2. Brother MFC-490CW Wireless module Replacement, Unplug the panel from the rest of the printer: 2 단계, 이미지 3개 중 1개 Brother MFC-490CW Wireless module Replacement, Unplug the panel from the rest of the printer: 2 단계, 이미지 3개 중 2개 Brother MFC-490CW Wireless module Replacement, Unplug the panel from the rest of the printer: 2 단계, 이미지 3개 중 3개
    • Lift up the front panel from the device.
    • Gently lift up and disconnect the data cables that attach the panel to the printer.
  3. Brother MFC-490CW Wireless module Replacement, Remove the screw: 3 단계, 이미지 1개 중 1개
    • Unscrew the 14.1mm screw located at the left side of the device.
    • Unscrew the 12.1mm screw to the right of the 14.1mm screw.
  4. Brother MFC-490CW Wireless module Replacement: 4 단계, 이미지 3개 중 1개 Brother MFC-490CW Wireless module Replacement: 4 단계, 이미지 3개 중 2개 Brother MFC-490CW Wireless module Replacement: 4 단계, 이미지 3개 중 3개
    • Pry open the left front panel away from the printer
    • Be careful. The panel is attached with a data cable.
  5. Brother MFC-490CW Wireless module Replacement: 5 단계, 이미지 2개 중 1개 Brother MFC-490CW Wireless module Replacement: 5 단계, 이미지 2개 중 2개
    • Carefully unplug the connector attached to the device.
  6. Brother MFC-490CW Wireless module Replacement, Remove the module from the panel: 6 단계, 이미지 3개 중 1개 Brother MFC-490CW Wireless module Replacement, Remove the module from the panel: 6 단계, 이미지 3개 중 2개 Brother MFC-490CW Wireless module Replacement, Remove the module from the panel: 6 단계, 이미지 3개 중 3개
    • Separate the two clips that hold the module in place.
    • Lift up the module.
결론
To reassemble your wireless module, follow these instructions in reverse order.
작성자
6다른 기여자 명과 함께
Matt
회원 가입일: 10/30/14
64 평판
안내서 2개를 작성함
UMass Dartmouth, Team 4-4, Miles Fall 2014 UMass Dartmouth, Team 4-4, Miles Fall 2014 회원
UMASSD-MILES-F14S4G4
3 회원들
안내서 11개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 26
전체 시간: 2,183
