주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Brother MFC-9130CW Ink Cartridge Replacement
필요한 것
  1. Brother MFC-9130CW Ink Cartridge Replacement, Ink Cartridge Replacement: 1 단계, 이미지 1개 중 1개
    • Press the power button on the printer for a couple of seconds to turn it off.
  2. Brother MFC-9130CW Ink Cartridge Replacement: 2 단계, 이미지 2개 중 1개 Brother MFC-9130CW Ink Cartridge Replacement: 2 단계, 이미지 2개 중 2개
    • Press the latch beneath the paper output area and lift it to access the ink compartment.
  3. Brother MFC-9130CW Ink Cartridge Replacement: 3 단계, 이미지 1개 중 1개
    • Identify the specific ink color you wish to replace among the available cartridges in the ink compartment.
  4. Brother MFC-9130CW Ink Cartridge Replacement: 4 단계, 이미지 2개 중 1개 Brother MFC-9130CW Ink Cartridge Replacement: 4 단계, 이미지 2개 중 2개
    • Pull each ink cartridge tray out of its slot using the center handle.
  5. Brother MFC-9130CW Ink Cartridge Replacement: 5 단계, 이미지 2개 중 1개 Brother MFC-9130CW Ink Cartridge Replacement: 5 단계, 이미지 2개 중 2개
    • Place the new ink cartridge on a clean surface.
    • Release the orange cover, as shown on the photo.
    • To prevent making a mess, set a paper towel on the counter or table in case of a spill during the replacement process.
  6. Brother MFC-9130CW Ink Cartridge Replacement: 6 단계, 이미지 2개 중 1개 Brother MFC-9130CW Ink Cartridge Replacement: 6 단계, 이미지 2개 중 2개
    • Place the cartridge in the tray.
    • Gently press down on the ink tray with your thumb.
    • You should hear a click, ensuring that the new ink cartridge is secure in its place.
  7. Brother MFC-9130CW Ink Cartridge Replacement: 7 단계, 이미지 3개 중 1개 Brother MFC-9130CW Ink Cartridge Replacement: 7 단계, 이미지 3개 중 2개 Brother MFC-9130CW Ink Cartridge Replacement: 7 단계, 이미지 3개 중 3개
    • Slide the ink tray back into its original position within the printer.
    • Make sure it is properly aligned and secure within the compartment.
    • Once the ink tray is secured, press the ink compartment latch with your thumb, and gently close the lid.
  8. Brother MFC-9130CW Ink Cartridge Replacement: 8 단계, 이미지 1개 중 1개
    • Press the power button for a couple of seconds to turn the printer back on.
    • Print a couple of test copies to ensure the toner cartridge replacement was a success.
결론
To reassemble your device, follow these instructions in the given order.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Kamaljot
회원 가입일: 01/08/24
184 평판
안내서 1개를 작성함
York University, Team 2-28, O'Regan Winter 2024 York University, Team 2-28, O'Regan Winter 2024 회원
YORK-O'REGAN-W24S2G28
1 회원
안내서 2개를 작성함
1가이드 댓글
One step is missing : release the orange cover.
Artefil - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 34
전체 시간: 606
