주요 콘텐츠로 건너뛰기
Brother PT-1010 Battery Replacement
  1. Brother PT-1010 Battery Replacement, Removing Back Panel: 1 단계, 이미지 1/1
    • Turn device so you are looking down at the top
  2. Brother PT-1010 Battery Replacement: 2 단계, 이미지 1/2 Brother PT-1010 Battery Replacement: 2 단계, 이미지 2/2
    • Press firmly on arrow indicator and pull panel toward you.
  3. Brother PT-1010 Battery Replacement, Remove Dead Batteries: 3 단계, 이미지 1/1
    • Remove dead batteries one at a time by pulling up on the side indicated with a + symbol.
    • Make sure the battery compartment is empty and clear of debris.
  4. Brother PT-1010 Battery Replacement: 4 단계, 이미지 1/2 Brother PT-1010 Battery Replacement: 4 단계, 이미지 2/2
    • Insert the first battery with the flat side (indicated by a - symbol on the battery) facing to the left of the battery compartment.
    • Do the same thing to insert the next 2 batteries.
  5. Brother PT-1010 Battery Replacement: 5 단계, 이미지 1/1
    • The next 3 batteries will be inserted on top of the others.
    • Insert the 4th battery with the flat side (indicated by the - symbol on the battery) facing to the right of the battery compartment.
  6. Brother PT-1010 Battery Replacement: 6 단계, 이미지 1/1
    • Repeat step 5 to insert the last 2 batteries.
  7. Brother PT-1010 Battery Replacement, Replace Back Panel: 7 단계, 이미지 1/1
    • Reinsert back panel.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Haley Sweet
회원 가입일: 10/30/14
460 평판
안내서 4개 작성하였습니다
Baylor, Team 4-4, Williams Fall 2014 Baylor, Team 4-4, Williams Fall 2014 회원
BU-WILLIAMS-F14S4G4
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 23
전체 시간: 4,826
