주요 콘텐츠로 건너뛰기
Brother PT-1010 Cassette Tape Replacement
필요한 것
  1. Brother PT-1010 Cassette Tape Replacement, Remove Back Cover: 1 단계, 이미지 1/1
    • Remove the back cover of the device by simultaneously pressing down on the indication arrows on the top center, then pulling toward you.
  2. Brother PT-1010 Cassette Tape Replacement, Insert Tape Cassette: 2 단계, 이미지 1/1
    • Brother TZ tape is required for this replacement process. We don't have the tape cassette but you should be able to insert tape cassette into the red marked area as shown in the picture.
    • Insert tape cassette into the red marked area as shown in the picture.
    • Make sure the cassette snaps into place by applying a small amount of pressure.
결론
Haley Sweet
회원 가입일: 10/30/14
460 평판
안내서 4개 작성하였습니다
Baylor, Team 4-4, Williams Fall 2014 Baylor, Team 4-4, Williams Fall 2014 회원
BU-WILLIAMS-F14S4G4
4 회원들
안내서 4개 작성하였습니다
댓글 3개
So if you've replaced the cassette and it still won't print now what??
Sara Mullaney - 답글
This was supposed to help with model PT-450D which looks nothing like this. Please help. I can’t REMOVE / replace the cassette !!! It is STUCK inside the label printer!
af4k - 답글
I have a PT-1880 model and replaced the cassette, but whenever I type something to label something, the label comes out blank. Can someone help me on this? I’ve been needing help on this for a while now.
Yael Rzoque - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 19
전체 시간: 3,259
