주요 콘텐츠로 건너뛰기
Brother PT-1010 Keyboard Replacement
필요한 것
  1. Brother PT-1010 Keyboard Replacement, Remove Back Cover: 1 단계, 이미지 1개 중 1개
    • Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
  2. Brother PT-1010 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Remove batteries, cassette tape, and cutter blade.
  3. Brother PT-1010 Keyboard Replacement, Remove Screws: 3 단계, 이미지 1개 중 1개
    • Use a phillips size #00 screwdriver to unscrew the 5 corner screws circled in the picture.
  4. Brother PT-1010 Keyboard Replacement, Separate Device: 4 단계, 이미지 1개 중 1개
    • Separate the top of the device from the bottom. Be very cautious when you separate the device, there is a ribbon attaching the top to the bottom.
  5. Brother PT-1010 Keyboard Replacement, Remove side panels: 5 단계, 이미지 1개 중 1개
    • Remove the two black side panels. They will easily fall out so just move them to the side until you are putting your device back together.
  6. Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: 6 단계, 이미지 3개 중 1개 Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: 6 단계, 이미지 3개 중 2개 Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: 6 단계, 이미지 3개 중 3개
    • Using your index finger and thumb, pull out the golden ribbon from the green circuit board.
  7. Brother PT-1010 Keyboard Replacement, Remove Screws from Circuit Board: 7 단계, 이미지 1개 중 1개
    • Use a phillips size #00 screwdriver to remove the two screws, circled in red, from the green circuit board.
  8. Brother PT-1010 Keyboard Replacement, Remove Circuit Board: 8 단계, 이미지 1개 중 1개
    • Carefully remove the green circuit board by pulling it straight up. Be careful not to break the LCD cable ribbon that connects the circuit board to the device.
    • The ribbon is very fragile so be careful to break it when pulling up on the circuit board.
  9. Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: 9 단계, 이미지 3개 중 1개 Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: 9 단계, 이미지 3개 중 2개 Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: 9 단계, 이미지 3개 중 3개
    • Underneath the circuit board you will find the rubber keyboard. Peel this off and remove it from the device.
결론
작성자
3다른 기여자 명과 함께
Haley Sweet
회원 가입일: 10/30/14
460 평판
안내서 4개를 작성함
Baylor, Team 4-4, Williams Fall 2014 Baylor, Team 4-4, Williams Fall 2014 회원
BU-WILLIAMS-F14S4G4
4 회원들
안내서 4개를 작성함
3가이드 댓글
Hi!
Thanks for this very helpful and detailed set of instructions. One small suggestion - assuming that replacing the keyboard means you need a working one to replace the old one with, you might want to consider adding “Parts: replacement keyboard” instead of “No parts required.”
Cheers,
Maria B
Maria Bitterli - 답글
Please specify what is being replaced. Is the rubber keyboard the part that needs to be replaced?
Sincere Cavalier - 답글
Screen is dull, what to do
Judy Baranczyk - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 27
전체 시간: 3,320
