주요 콘텐츠로 건너뛰기
Brother PT-110 Printer Motor Replacement
필요한 것
  1. Brother PT-110 Printer Motor Replacement, Batteries: 1 단계, 이미지 1/2 Brother PT-110 Printer Motor Replacement, Batteries: 1 단계, 이미지 2/2
    • Push on the side of the cover, and remove it.
  2. Brother PT-110 Printer Motor Replacement: 2 단계, 이미지 1/1
    • Remove the batteries.
  3. Brother PT-110 Printer Motor Replacement, Back Plate: 3 단계, 이미지 1/2 Brother PT-110 Printer Motor Replacement, Back Plate: 3 단계, 이미지 2/2
    • Unscrew the two 9 mm Phillips #1 screws from the top and bottom.
    • Total: 2 x Screws
  4. Brother PT-110 Printer Motor Replacement: 4 단계, 이미지 1/1
    • First: To separate the top cover from the body, insert a spudger between the two halves.
    • Gently twist the spudger until the two halves separate. Do this in multiple spots around the perimeter of the cover to distribute the pressure.
    • DO NOT PULL HALVES APART. There are wired connections inside that must be disconnected before halves can be fully separated.
  5. Brother PT-110 Printer Motor Replacement: 5 단계, 이미지 1/1
    • Gently separate the two covers, ensuring wires are not taut.
  6. Brother PT-110 Printer Motor Replacement: 6 단계, 이미지 1/1
    • Gently grasp the ribbon wire and top cover, then gently pull the ribbon wire out of its connection.
  7. Brother PT-110 Printer Motor Replacement: 7 단계, 이미지 1/2 Brother PT-110 Printer Motor Replacement: 7 단계, 이미지 2/2
    • Carefully pinch the top of the connector.
    • Pull perpendicular to the device until the wire is disconnected.
    • It may require more force than expected to disconnect the wires.
  8. Brother PT-110 Printer Motor Replacement: 8 단계, 이미지 1/3 Brother PT-110 Printer Motor Replacement: 8 단계, 이미지 2/3 Brother PT-110 Printer Motor Replacement: 8 단계, 이미지 3/3
    • Unscrew the three 9 mm Phillips #1 screws shown.
    • Total: 3 x Screws
  9. Brother PT-110 Printer Motor Replacement, Printer Motor: 9 단계, 이미지 1/1
    • Remove the motor housing.
  10. Brother PT-110 Printer Motor Replacement: 10 단계, 이미지 1/2 Brother PT-110 Printer Motor Replacement: 10 단계, 이미지 2/2
    • Unscrew the two 3 mm Phillips #1 screws from the motor housing.
    • Total: 2 x Screws
  11. Brother PT-110 Printer Motor Replacement: 11 단계, 이미지 1/1
    • Remove the motor.
결론
Kimberly Larsen
회원 가입일: 09/28/16
237 평판
안내서 5개 작성하였습니다
IUPUI, Team 1-1, Harley Fall 2016 IUPUI, Team 1-1, Harley Fall 2016 회원
IUPUI-HARLEY-F16S1G1
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 821
