주요 콘텐츠로 건너뛰기
Brother PT-1290 Battery/AC Adapter Replacment
  1. Brother PT-1290 Battery/AC Adapter Replacment, Brother PT-1290 Battery/AC Adapter: 1 단계, 이미지 1/3 Brother PT-1290 Battery/AC Adapter Replacment, Brother PT-1290 Battery/AC Adapter: 1 단계, 이미지 2/3 Brother PT-1290 Battery/AC Adapter Replacment, Brother PT-1290 Battery/AC Adapter: 1 단계, 이미지 3/3
    • First, flip over your label maker and push down on the top part(by the face plate) and push on the circle part with ridges. Next open the label maker carefully to prevent any damage.
  2. Brother PT-1290 Battery/AC Adapter Replacment: 2 단계, 이미지 1/1
    • Once the label maker is open, remove the six AAA drained batteries.
    • If your using an AC adapter, replace the old one with the new HQRP adapter.
    • If you see white on the batteries, that would be corrosion. Be careful when disposing.
  3. Brother PT-1290 Battery/AC Adapter Replacment: 3 단계, 이미지 1/3 Brother PT-1290 Battery/AC Adapter Replacment: 3 단계, 이미지 2/3 Brother PT-1290 Battery/AC Adapter Replacment: 3 단계, 이미지 3/3
    • Now place in the new six AAA batteries.
    • Make sure the batteries are correctly in and touching the golden prongs.
결론
Lorraine Canez
회원 가입일: 10/25/14
318 평판
안내서 3개 작성하였습니다
Gateway, Team 1-4, Johnson Fall 2014 Gateway, Team 1-4, Johnson Fall 2014 회원
GCC-JOHNSON-F14S1G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 15
전체 시간: 882
