주요 콘텐츠로 건너뛰기
Brother PT-1290 Keyboard Replacement
필요한 것
  1. Brother PT-1290 Keyboard Replacement, Turn over device to remove batteries.: 1 단계, 이미지 1/3 Brother PT-1290 Keyboard Replacement, Turn over device to remove batteries.: 1 단계, 이미지 2/3 Brother PT-1290 Keyboard Replacement, Turn over device to remove batteries.: 1 단계, 이미지 3/3
    • Turn the device to it's side toward the bottom of the keyboard. Then pop open the case and remove the batteries.
  2. Brother PT-1290 Keyboard Replacement, Back of device: 2 단계, 이미지 1/3 Brother PT-1290 Keyboard Replacement, Back of device: 2 단계, 이미지 2/3 Brother PT-1290 Keyboard Replacement, Back of device: 2 단계, 이미지 3/3
    • Remove back of device and set aside.
  3. Brother PT-1290 Keyboard Replacement, Remove screws: 3 단계, 이미지 1/3 Brother PT-1290 Keyboard Replacement, Remove screws: 3 단계, 이미지 2/3 Brother PT-1290 Keyboard Replacement, Remove screws: 3 단계, 이미지 3/3
    • Remove all 1/4 inch screws(6 total) with a (+PH00) screwdriver. Open slowly not to damage the display data cable.
  4. Brother PT-1290 Keyboard Replacement, Remove flat panel: 4 단계, 이미지 1/3 Brother PT-1290 Keyboard Replacement, Remove flat panel: 4 단계, 이미지 2/3 Brother PT-1290 Keyboard Replacement, Remove flat panel: 4 단계, 이미지 3/3
    • Use a plastic opening tool to remove the flat-panel membrane keyboard. Lift up and set aside.
  5. Brother PT-1290 Keyboard Replacement, Remove: 5 단계, 이미지 1/3 Brother PT-1290 Keyboard Replacement, Remove: 5 단계, 이미지 2/3 Brother PT-1290 Keyboard Replacement, Remove: 5 단계, 이미지 3/3
    • Use a spudger to aid in removing the keyboard.
    • Gently lift out while removing the LCD screen that is connected to the data cable and finishing removing.
결론
Angela Araujo
회원 가입일: 10/24/14
99 평판
안내서 1개 작성함
Gateway, Team 1-4, Johnson Fall 2014 Gateway, Team 1-4, Johnson Fall 2014 회원
GCC-JOHNSON-F14S1G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 7
전체 시간: 478
