주요 콘텐츠로 건너뛰기
Brother PT-90 Personal Labeler Disassembly
필요한 것
  1. Brother PT-90 Personal Labeler Disassembly, Brother PT-90 Personal Labeler Disassembly: 1 단계, 이미지 1/2 Brother PT-90 Personal Labeler Disassembly, Brother PT-90 Personal Labeler Disassembly: 1 단계, 이미지 2/2
    • Start with your device off. The screen should be blank and not displaying anything.
    • Turn the device over so it's resting face down.
    • You should be able to see the model name of the label-maker, as well as a window in which you can view the label cartridge.
  2. Brother PT-90 Personal Labeler Disassembly: 2 단계, 이미지 1/3 Brother PT-90 Personal Labeler Disassembly: 2 단계, 이미지 2/3 Brother PT-90 Personal Labeler Disassembly: 2 단계, 이미지 3/3
    • Using your thumb, press in and then upward on the fastener at the top of the device. The back of the device should come off easily.
    • Remove the 4 batteries located on the left side of the device.
  3. Brother PT-90 Personal Labeler Disassembly: 3 단계, 이미지 1/3 Brother PT-90 Personal Labeler Disassembly: 3 단계, 이미지 2/3 Brother PT-90 Personal Labeler Disassembly: 3 단계, 이미지 3/3
    • To remove the label cartridge from the device, use a plastic opening tool from your iFixit tool kit.
  4. Brother PT-90 Personal Labeler Disassembly: 4 단계, 이미지 1/3 Brother PT-90 Personal Labeler Disassembly: 4 단계, 이미지 2/3 Brother PT-90 Personal Labeler Disassembly: 4 단계, 이미지 3/3
    • Attach the J1 Screwdriver Bit to the extension tool from your tool kit.
    • Remove all of the screws from the back of the device.
  5. Brother PT-90 Personal Labeler Disassembly: 5 단계, 이미지 1/2 Brother PT-90 Personal Labeler Disassembly: 5 단계, 이미지 2/2
    • Once the screws have been removed, press as shown on the fastener.
    • Carefully open the device.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Tessa Hathaway
회원 가입일: 10/13/16
148 평판
안내서 1개 작성함
University of Maine, Team 2-1, Diaz Fall 2016 University of Maine, Team 2-1, Diaz Fall 2016 회원
UMAINE-DIAZ-F16S2G1
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 23
전체 시간: 794
