주요 콘텐츠로 건너뛰기
Brother PT-D200 Cutter Blade Replacement
  1. Brother PT-D200 Cutter Blade Replacement, Cutter Blade: 1 단계, 이미지 1/2 Brother PT-D200 Cutter Blade Replacement, Cutter Blade: 1 단계, 이미지 2/2
    • Open the back panel of the device by pressing down on and then pulling the indication arrows on the top center of the cover upward towards you.
  2. Brother PT-D200 Cutter Blade Replacement: 2 단계, 이미지 1/1
    • Locate the cutter blade unit (mint green) as shown in the picture.
  3. Brother PT-D200 Cutter Blade Replacement: 3 단계, 이미지 1/2 Brother PT-D200 Cutter Blade Replacement: 3 단계, 이미지 2/2
    • Using the thumb and forefinger, pull up, applying a moderate amount of pressure until the cutter blade unit loosens and is removed.
    • The blade is sharp.
결론
Blaire McCreary
회원 가입일: 01/24/14
201 평판
안내서 2개 작성하였습니다
Cal Poly, Team 13-16, Regan Winter 2014 Cal Poly, Team 13-16, Regan Winter 2014 회원
CPSU-REGAN-W14S13G16
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
Where can you order the replacement blade?
mistymeziere - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 13
30일 전: 45
전체 시간: 3,089
