주요 콘텐츠로 건너뛰기
Brother PT-D200 Keyboard Replacement
필요한 것
  1. Brother PT-D200 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
  2. Brother PT-D200 Keyboard Replacement: 2 단계, 이미지 1/1
    • Remove the six AAA batteries.
  3. Brother PT-D200 Keyboard Replacement, Back of Device: 3 단계, 이미지 1/1
    • Use the Helping Hand 1/4" screwdriver to unscrew the six 3/16" corner screws.
  4. Brother PT-D200 Keyboard Replacement: 4 단계, 이미지 1/1
    • Close the back cover and then flip the device over and separate the top half from the bottom half as shown.
    • Be gentle when lifting the top of the device, there is a ribbon cable attaching the two halves together.
  5. Brother PT-D200 Keyboard Replacement, Face Plate: 5 단계, 이미지 1/1
    • On the top portion of the device there are four grey clips locking the faceplate in place. The two top clips are circled in the image. The two others are located in the other corners of the device.
  6. Brother PT-D200 Keyboard Replacement: 6 단계, 이미지 1/2 Brother PT-D200 Keyboard Replacement: 6 단계, 이미지 2/2
    • Pull the clips inward two at a time, first the top then the bottom, to snap the face plate off.
  7. Brother PT-D200 Keyboard Replacement, Keyboard: 7 단계, 이미지 1/2 Brother PT-D200 Keyboard Replacement, Keyboard: 7 단계, 이미지 2/2
    • Peel off the rubber keyboard of the device.
결론
[deleted]
회원 가입일: 01/24/14
301 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 467
