주요 콘텐츠로 건너뛰기
Brother Printer DCP-L2540DW Toner Cartridge Replacement
  1. Brother Printer DCP-L2540DW Toner Cartridge Replacement, Toner Cartridge: 1 단계, 이미지 1개 중 1개
    • Pull the center paper tray extender to expose the drum unit.
  2. Brother Printer DCP-L2540DW Toner Cartridge Replacement: 2 단계, 이미지 1개 중 1개
    • Gently pull the drum unit out of the printer at a slight incline angle.
  3. Brother Printer DCP-L2540DW Toner Cartridge Replacement: 3 단계, 이미지 2개 중 1개 Brother Printer DCP-L2540DW Toner Cartridge Replacement: 3 단계, 이미지 2개 중 2개
    • Push down on the lever lock to unlock the cartridge from the drum unit.
    • Remove the cartridge from the drum unit and recycle it.
  4. Brother Printer DCP-L2540DW Toner Cartridge Replacement: 4 단계, 이미지 2개 중 1개 Brother Printer DCP-L2540DW Toner Cartridge Replacement: 4 단계, 이미지 2개 중 2개
    • Unpack the new toner cartridge from its packaging.
    • Gently shake the cartridge to evenly distribute the toner throughout the printer transfer roller.
  5. Brother Printer DCP-L2540DW Toner Cartridge Replacement: 5 단계, 이미지 3개 중 1개 Brother Printer DCP-L2540DW Toner Cartridge Replacement: 5 단계, 이미지 3개 중 2개 Brother Printer DCP-L2540DW Toner Cartridge Replacement: 5 단계, 이미지 3개 중 3개
    • Remove protective cover enclosing the printer transfer roller
    • AVOID CONTACT WITH PRINTER TRANSFER ROLLER. This could potentially damage the device.
    • Insert the new cartridge in the drum unit.
    • A click should be heard to acknowledge the toner cartridge has been fitted properly.
  6. Brother Printer DCP-L2540DW Toner Cartridge Replacement: 6 단계, 이미지 3개 중 1개 Brother Printer DCP-L2540DW Toner Cartridge Replacement: 6 단계, 이미지 3개 중 2개 Brother Printer DCP-L2540DW Toner Cartridge Replacement: 6 단계, 이미지 3개 중 3개
    • Clean the corona wire with the slide tab near the front side of the drum unit by sliding it left and right several times.
    • Return the slide tab back to its original position before continuing.
  7. Brother Printer DCP-L2540DW Toner Cartridge Replacement: 7 단계, 이미지 3개 중 1개 Brother Printer DCP-L2540DW Toner Cartridge Replacement: 7 단계, 이미지 3개 중 2개 Brother Printer DCP-L2540DW Toner Cartridge Replacement: 7 단계, 이미지 3개 중 3개
    • Insert the drum unit with the new toner cartridge attached at a slight incline back into the printer.
    • Remember to have the drum unit pushed in enough for the front cover to be able to close.
    • You have now successfully completed replacing the toner cartridge for your Brother DCP-L2540DW Printer.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Garvish Patel
회원 가입일: 05/12/21
175 평판
안내서 1개를 작성함
2가이드 댓글
I have done this process and the printer is still telling saying that we need to put in toner?? Can not figure out why?? Any help??
Ed Reinstein - 답글
It still tells me that I need to replace the toner can I get se help please
Lisbet Aldana - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 41
지난 30일: 198
전체 시간: 8,710
