주요 콘텐츠로 건너뛰기
Brother Printer HL 3140 CW Paper Jam fix
필요한 것
  1. Brother Printer HL 3140 CW Paper Jam fix, take off back cover: 1 단계, 이미지 2개 중 1개 Brother Printer HL 3140 CW Paper Jam fix, take off back cover: 1 단계, 이미지 2개 중 2개
    • Stick your printer on a table and get to the back of it. Then remove the white flap from its hinges. you may need to bend the plastic a little for the plastic studs to pop out.
  2. Brother Printer HL 3140 CW Paper Jam fix, remove inside cover: 2 단계, 이미지 2개 중 1개 Brother Printer HL 3140 CW Paper Jam fix, remove inside cover: 2 단계, 이미지 2개 중 2개
    • With the white flap off, unscrew the single screw and pry out this black cover.
    • Once out this will allow you to un-clip and remove the paper guide from the printer.( pinch the two green levers)
  3. Brother Printer HL 3140 CW Paper Jam fix, remove photocell shroud: 3 단계, 이미지 2개 중 1개 Brother Printer HL 3140 CW Paper Jam fix, remove photocell shroud: 3 단계, 이미지 2개 중 2개
    • You now have access to the black shroud that covers the photocell emitter & receiver. Pry it upwards and off with a small opening tool.
    • Inspect the paperguide: a small black spring loaded lever in the middle should move the "blocking piece" freely up and down.
    • Reassemble in reverse order, ensuring the blocking piece moves freely between the photocell emitter & receiver.
결론
To reassemble your device, follow these instructions in reverse order. This may be the fix you are looking for or perhaps your printer has a different issue. Clearly a slight knock to this plastic shroud meant the photocells were no longer aligned and this printer was unusable...until now.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Peter van-Velzen
회원 가입일: 06/24/17
233 평판
안내서 1개를 작성함
15가이드 댓글
OMG THANK YOU SO MUCH! I have spent untold hours on the phone with Brother — and finally ran across your post. Worked in 2 minutes. THANKS!
Jason Martin - 답글
It’s not explicitly clear here - but what you are doing is removing and LEAVING OUT the black U shaped shroud from the device.
brantwalsh - 답글
OMG thank you... I took it apart and didn't see whatever spring thing he was talking about was, and read your comment and my printer is working again.
Gregory Beaber Jr -
Wow, you nailed it! As soon as I read your observation that the machine always stopped at exactly the same spot - despite there being no paper jam - my mood changed. It worked like a charm. Thanks for sharing the experience with others.
Stuart Clark - 답글
Thank you! Totally worked. To add to post we removed the shroud and left it off.
jen_phan - 답글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 17
지난 30일: 87
전체 시간: 7,044
