주요 콘텐츠로 건너뛰기
Brother XM3700 Broken Needle Replacement
필요한 것
  1. Brother XM3700 Broken Needle Replacement, Broken Needle: 1 단계, 이미지 3개 중 1개 Brother XM3700 Broken Needle Replacement, Broken Needle: 1 단계, 이미지 3개 중 2개 Brother XM3700 Broken Needle Replacement, Broken Needle: 1 단계, 이미지 3개 중 3개
    • Adjust the needle with the handwheel towards you until it is at the highest position, as indicated by the silver thread take-up lever.
  2. Brother XM3700 Broken Needle Replacement: 2 단계, 이미지 2개 중 1개 Brother XM3700 Broken Needle Replacement: 2 단계, 이미지 2개 중 2개
    • Unscrew the bolt that holds the needle in place using either the tool that came with your Brother machine, or a small flat object like a coin.
  3. Brother XM3700 Broken Needle Replacement: 3 단계, 이미지 2개 중 1개 Brother XM3700 Broken Needle Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the broken needle stem from the machine, and dispose of it carefully.
  4. Brother XM3700 Broken Needle Replacement: 4 단계, 이미지 2개 중 1개 Brother XM3700 Broken Needle Replacement: 4 단계, 이미지 2개 중 2개
    • Unthread the broken needle tip from the thread, and dispose of carefully.
  5. Brother XM3700 Broken Needle Replacement: 5 단계, 이미지 2개 중 1개 Brother XM3700 Broken Needle Replacement: 5 단계, 이미지 2개 중 2개
    • Select a Brother brand needle, using the needle size that works well with your fabric.
  6. Brother XM3700 Broken Needle Replacement: 6 단계, 이미지 2개 중 1개 Brother XM3700 Broken Needle Replacement: 6 단계, 이미지 2개 중 2개
    • Insert the needle with the flat side of the stem facing the back of the machine.
  7. Brother XM3700 Broken Needle Replacement: 7 단계, 이미지 1개 중 1개
    • Screw the bolt in first with your fingers and then with the tool until the needle is tightly secured.
  8. Brother XM3700 Broken Needle Replacement: 8 단계, 이미지 2개 중 1개 Brother XM3700 Broken Needle Replacement: 8 단계, 이미지 2개 중 2개
    • Rethread the needle and pull the thread through the back.
결론
Congratulations! You have successfully replaced your broken needle. Happy sewing!
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Nadya Verick
회원 가입일: 02/07/23
178 평판
안내서 1개를 작성함
UC Davis, Team 1-6, Andersen Winter 2023 UC Davis, Team 1-6, Andersen Winter 2023 회원
UCD-ANDERSEN-W23S1G6
4 회원들
안내서 1개 작성
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 12
전체 시간: 422
