필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Place the machine on a solid surface.
Remove the 14mm Phillips #2 screw holding on the face cover.
Remove the two 14mm Phillips #2 screws and two 22mm Phillips #2 screws that secure the rear casing.
Lay the machine on its side.
Remove the four 10mm Phillips #2 screws that hold the bottom panel in place.
Place the machine on its side, with access to the bottom.
Gently pull out the white wire connecting the bulb to the machine.
Place the machine upright.
Using the flathead screwdriver, remove the 5mm Flathead screw holding on the lightbulb bracket.
다른 한 분이 해당 안내서를 완성하였습니다.
