주요 콘텐츠로 건너뛰기
Buffalo Linkstation mini LS-WSXL Disassembly
필요한 것
  1. Buffalo Linkstation mini LS-WSXL Disassembly, Remove front strip: 1 단계, 이미지 2개 중 1개 Buffalo Linkstation mini LS-WSXL Disassembly, Remove front strip: 1 단계, 이미지 2개 중 2개
    • Using a thin blade, gently prise the strip-sticker from the front of the unit.
  2. Buffalo Linkstation mini LS-WSXL Disassembly, Splitting the case: 2 단계, 이미지 2개 중 1개 Buffalo Linkstation mini LS-WSXL Disassembly, Splitting the case: 2 단계, 이미지 2개 중 2개
    • There are two catches to release on the front face.
    • Using the iFixit opening tools, insert the first blade between the long opening and the first hole.
    • The second blade should be inserted between the third and fourth holes
    • Gently manipulate the tools to disengage the catches.
    • Open the case wider to be able to get the ifixit tools in the gap on the side of the unit - go to the next step.
  3. Buffalo Linkstation mini LS-WSXL Disassembly, Removing the lid: 3 단계, 이미지 2개 중 1개 Buffalo Linkstation mini LS-WSXL Disassembly, Removing the lid: 3 단계, 이미지 2개 중 2개
    • The first catch is next to the rubber foot. Insert the tool under the lip and lift the side to disengage the catch
    • The second catch can be found at the beginning of the vents, use the same technique to open the catch
    • Repeat the steps on the opposite side and the lid will come off.
  4. Buffalo Linkstation mini LS-WSXL Disassembly, Removing the hard drives: 4 단계, 이미지 3개 중 1개 Buffalo Linkstation mini LS-WSXL Disassembly, Removing the hard drives: 4 단계, 이미지 3개 중 2개 Buffalo Linkstation mini LS-WSXL Disassembly, Removing the hard drives: 4 단계, 이미지 3개 중 3개
    • Pull the until out of the case, there are no catches, it is simply held in.
    • Place the unit on it's side and remove the metal plate that is clamped to the board.
    • Turn the unit over the remove the second plate.
    • The hard drives can now be removed.
  5. Buffalo Linkstation mini LS-WSXL Disassembly, Finished!: 5 단계, 이미지 2개 중 1개 Buffalo Linkstation mini LS-WSXL Disassembly, Finished!: 5 단계, 이미지 2개 중 2개
    • The unit is now disassembled, assembly is simply done in the reverse order.
    • When reassembling the unit, pay attention to the orientation of the metal plates.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
granted3
573 평판
안내서 1개를 작성함
댓글 4개
I have the 2x1TB version and DID manage to successfully replace HDD's with SSD's! I only had 500GB SSD's and don't recall having any problems (but it was years ago though). I do have a number of downloaded utilities, including TFTP Boot Recovery (presumably from Buffalo website) so it's possible I had to use this (too long ago to recall)!
Andrew Blay - 답글
I need the TFTP Boot Recovery files. Have you the files?
Michael Gebert -
Thanks to all...I opened it without breaking anything thanks to you.
Maurizio Spinelli - 답글
Put an an initialised but unformatted SSD in slot #2 and it is seen by the device but upon formatting it says "failed to operate disk. please resummit after restart". When I insert a regular HDD this message does not appear. Any idea?
Greybox - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 60
전체 시간: 2,863
