주요 콘텐츠로 건너뛰기
Bugaboo Cameleon 1 and 3 Handlebar Clip Replacement
필요한 것
  1. Bugaboo Cameleon 1 and 3  Handlebar Clip Replacement, Remove old part: 1 단계, 이미지 2개 중 1개 Bugaboo Cameleon 1 and 3  Handlebar Clip Replacement, Remove old part: 1 단계, 이미지 2개 중 2개
    • Loosen the screw using the torx screwdriver.
    • Make sure to catch the nut that will fall out at the bottom, by holding the other hand underneath the clip.
    • Make sure not to lose the screw since you will need it later for the reassembly.
  2. Bugaboo Cameleon 1 and 3  Handlebar Clip Replacement, Remove screw: 2 단계, 이미지 1개 중 1개
    • Use the screwdriver to push the screw up and out of the black part.
  3. Bugaboo Cameleon 1 and 3  Handlebar Clip Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the broken handlebar clip and the small part with the spring.
    • Make sure to keep the part with the spring, since that is not included if you use the 3D model used for this repair guide.
  4. Bugaboo Cameleon 1 and 3  Handlebar Clip Replacement: 4 단계, 이미지 2개 중 1개 Bugaboo Cameleon 1 and 3  Handlebar Clip Replacement: 4 단계, 이미지 2개 중 2개
    • Put the part with the spring back in.
    • Hold it in place while putting the new part back in place
  5. Bugaboo Cameleon 1 and 3  Handlebar Clip Replacement: 5 단계, 이미지 2개 중 1개 Bugaboo Cameleon 1 and 3  Handlebar Clip Replacement: 5 단계, 이미지 2개 중 2개
    • Place the torx screw back in place, and place the nut back onto the underside of the screw.
    • Hold it in place with one hand, while using the other hand to fasten the screw using the torx screwdriver.
  6. Bugaboo Cameleon 1 and 3  Handlebar Clip Replacement: 6 단계, 이미지 1개 중 1개
    • Adjust the handlebar according to your needs.
    • Close the clip. All done!
결승점
다른 3명이 해당 안내서를 완성하였습니다.
첨부 문서
작성자
2다른 기여자 명과 함께
Rebecca Dowling
회원 가입일: 04/24/18
692 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 22
전체 시간: 2,174
