주요 콘텐츠로 건너뛰기
Bugaboo Cameleon 1 and 3 Brake Handle Replacement
필요한 것
  1. Bugaboo Cameleon 1 and 3 Brake Handle Replacement, Brake Handle: 1 단계, 이미지 1개 중 1개
    • Remove both screws on the inner side of the black plastic part, connecting the brake to the frame.
    • Make sure not to lose the screws, since you will need them for the reassembly
  2. Bugaboo Cameleon 1 and 3 Brake Handle Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the left piece that is holding the brake handle.
  3. Bugaboo Cameleon 1 and 3 Brake Handle Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the brake line down and take the brake handle out of the black plastic part.
  4. Bugaboo Cameleon 1 and 3 Brake Handle Replacement: 4 단계, 이미지 1개 중 1개
    • Take the brake cable out of the groove in the brake handle.
  5. Bugaboo Cameleon 1 and 3 Brake Handle Replacement: 5 단계, 이미지 3개 중 1개 Bugaboo Cameleon 1 and 3 Brake Handle Replacement: 5 단계, 이미지 3개 중 2개 Bugaboo Cameleon 1 and 3 Brake Handle Replacement: 5 단계, 이미지 3개 중 3개
    • Pry the inside part out of the brake with a flat screwdriver.
    • Inside the brakes resides a spring. This can cause the part to fly out of the brake handle when the inner part is not clammed anymore.
  6. Bugaboo Cameleon 1 and 3 Brake Handle Replacement: 6 단계, 이미지 1개 중 1개
    • Put the spring into the replacement brake handle.
  7. Bugaboo Cameleon 1 and 3 Brake Handle Replacement: 7 단계, 이미지 1개 중 1개
    • Insert the inner piece of the brake handle into the replacement part. You have to align the small projection on the inner piece with the hole of the brake handle.
    • Use force until the inner piece is clamped into the brake handle.
  8. Bugaboo Cameleon 1 and 3 Brake Handle Replacement: 8 단계, 이미지 1개 중 1개
    • Insert the brake cable back into the brake handle.
    • The picture shows the brake handle without the inner parts inserted. This is not correct and you should first insert the inner pieces as shown in the previous steps before starting with this step.
  9. Bugaboo Cameleon 1 and 3 Brake Handle Replacement: 9 단계, 이미지 1개 중 1개
    • Insert the brake handle back into the frame.
  10. Bugaboo Cameleon 1 and 3 Brake Handle Replacement: 10 단계, 이미지 2개 중 1개 Bugaboo Cameleon 1 and 3 Brake Handle Replacement: 10 단계, 이미지 2개 중 2개
    • Insert the black inner piece onto the brake handle.
    • Screw the screws back into the frame using the Torx screwdriver.
  11. Bugaboo Cameleon 1 and 3 Brake Handle Replacement: 11 단계, 이미지 1개 중 1개
    • Enjoy your new brake handle!
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
첨부 문서
작성자
2다른 기여자 명과 함께
Rebecca Dowling
회원 가입일: 04/24/18
692 평판
안내서 3개를 작성함
1가이드 댓글
Nice, it looks awesome, im also missing the small plastic part, the one used to lock the brake. Do you also have the STL for that?
Thanks
andsk8 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 36
전체 시간: 3,404
