주요 콘텐츠로 건너뛰기
Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement
필요한 것
  1. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Detach the seat from the frame: 1 단계, 이미지 1개 중 1개
    • Push both the white square buttons under the seat at the same time, to remove the seat from the frame.
  2. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement: 2 단계, 이미지 1개 중 1개
    • Put the frame with the handle on the ground like shown in the picture, to have better access to the swivel wheels.
  3. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Detach swivel wheel: 3 단계, 이미지 1개 중 1개
    • Press the button above the swivel wheel, and pull out the swivel wheel
  4. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Remove screws: 4 단계, 이미지 3개 중 1개 Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Remove screws: 4 단계, 이미지 3개 중 2개 Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Remove screws: 4 단계, 이미지 3개 중 3개
    • Remove the two screws on the black cylinder on the bottom with the Torx screwdriver.
    • Make sure not to lose the screws, since you need them for the reassembly later.
  5. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the bottom part of the cylinder. You can use your screwdriver to pull it out.
  6. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Remove old part: 6 단계, 이미지 3개 중 1개 Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Remove old part: 6 단계, 이미지 3개 중 2개 Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Remove old part: 6 단계, 이미지 3개 중 3개
    • Push the old button, and place the flathead screwdriver behind the button
    • Push the button down and towards the opening of the cylinder.
    • Take out the wheel lock button and the spring, and make sure not to lose the spring.
  7. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Attaching the new part: 7 단계, 이미지 2개 중 1개 Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Attaching the new part: 7 단계, 이미지 2개 중 2개
    • Pull the spring from the old part.
    • Attach it to pin on the new swivel wheel lock.
  8. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Placing the new part in the stroller: 8 단계, 이미지 1개 중 1개
    • Put the new part with the spring back inside the cylinder, in the orientation shown in the picture.
  9. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Reassembling: 9 단계, 이미지 1개 중 1개
    • Place the inner black cylinder back into the outer cylinder.
  10. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Securing the part: 10 단계, 이미지 2개 중 1개 Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Securing the part: 10 단계, 이미지 2개 중 2개
    • Use the two screws and the Torx screwdriver to secure the parts.
  11. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Attach the wheel: 11 단계, 이미지 1개 중 1개
    • Click the wheel back onto the frame.
  12. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Put the stroller the right side up.: 12 단계, 이미지 2개 중 1개 Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Put the stroller the right side up.: 12 단계, 이미지 2개 중 2개
    • The repair is now finished. Flip the frame back onto four wheels.
    • Place the seat back onto the frame.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
첨부 문서
작성자
1다른 기여자 명과 함께
Rebecca Dowling
회원 가입일: 04/24/18
692 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 21
전체 시간: 2,547
