주요 콘텐츠로 건너뛰기
Bulova Precisionist 96B252 Link Replacement
필요한 것
  1. Bulova Precisionist 96B252 Link Replacement, Link: 1 단계, 이미지 1/1
    • Open the watchband and locate the arrows that are on the inside edge of the band.
  2. Bulova Precisionist 96B252 Link Replacement: 2 단계, 이미지 1/1
    • Place the watch onto the watch holder with the arrows pointing down.
  3. Bulova Precisionist 96B252 Link Replacement: 3 단계, 이미지 1/2 Bulova Precisionist 96B252 Link Replacement: 3 단계, 이미지 2/2
    • Align the 0.8 mm pin puncher to the link hole you want to remove.
    • Lightly tap the pin puncher with the soft side of the hammer until the pin comes out
    • The pin can be reused to attach the new link if it is not warped or damaged.
  4. Bulova Precisionist 96B252 Link Replacement: 4 단계, 이미지 1/1
    • Flip the watch so the arrows on the band are pointing up and away from the watch holder.
  5. Bulova Precisionist 96B252 Link Replacement: 5 단계, 이미지 1/3 Bulova Precisionist 96B252 Link Replacement: 5 단계, 이미지 2/3 Bulova Precisionist 96B252 Link Replacement: 5 단계, 이미지 3/3
    • Align the pinhole on the new link with the pinhole on the watch band.
    • Once the pin holes are lined up, position the pin over the holes
    • Use the soft side of the hammer to gently tap the pin into the links, connecting the new link to the watch.
  6. Bulova Precisionist 96B252 Link Replacement: 6 단계, 이미지 1/1
    • Once the pin is smoothly inserted into the band, try the watch on to ensure the new links are aligned and securely in place.
결론
To reassemble your watch, follow these instructions in reverse order.
Michael
회원 가입일: 09/13/23
133 평판
안내서 1개 작성함
York University, Team C-17, O'Regan Fall 2023 York University, Team C-17, O'Regan Fall 2023 회원
YORK-O'REGAN-F23SCG17
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 57
전체 시간: 305
