주요 콘텐츠로 건너뛰기
Bush Pump Above Grade Riser Pipe Replacement
필요한 것
  1. Bush Pump Above Grade Riser Pipe Replacement, Head and Handle: 1 단계, 이미지 1/2 Bush Pump Above Grade Riser Pipe Replacement, Head and Handle: 1 단계, 이미지 2/2
    • Test pump performance by pumping 40 strokes.
    • An effective pump should return at least 10 liters.
  2. Bush Pump Above Grade Riser Pipe Replacement: 2 단계, 이미지 1/2 Bush Pump Above Grade Riser Pipe Replacement: 2 단계, 이미지 2/2
    • Remove the two pins connecting the handle to the slider.
  3. Bush Pump Above Grade Riser Pipe Replacement: 3 단계, 이미지 1/2 Bush Pump Above Grade Riser Pipe Replacement: 3 단계, 이미지 2/2
    • Pull the two lever arms away from the slider.
  4. Bush Pump Above Grade Riser Pipe Replacement: 4 단계, 이미지 1/2 Bush Pump Above Grade Riser Pipe Replacement: 4 단계, 이미지 2/2
    • Lift the two pins attaching the pump frame to the head and handle up, off of the pump frame.
  5. Bush Pump Above Grade Riser Pipe Replacement: 5 단계, 이미지 1/3 Bush Pump Above Grade Riser Pipe Replacement: 5 단계, 이미지 2/3 Bush Pump Above Grade Riser Pipe Replacement: 5 단계, 이미지 3/3
    • Throughout this step, make sure you support the handle and head with at least three hands.
    • Slide the bearing rod out of the head.
    • Inspect the bearing rod and head for any wear or tear.
  6. Bush Pump Above Grade Riser Pipe Replacement: 6 단계, 이미지 1/1
    • Remove the head and handle, and place them on a clean surface to prevent contamination.
  7. Bush Pump Above Grade Riser Pipe Replacement, Riser Main Slider: 7 단계, 이미지 1/2 Bush Pump Above Grade Riser Pipe Replacement, Riser Main Slider: 7 단계, 이미지 2/2
    • Firmly lift the riser main slider with two hands.
    • Use caution not to drop the riser main, as this can damage the pump cylinder.
  8. Bush Pump Above Grade Riser Pipe Replacement: 8 단계, 이미지 1/3 Bush Pump Above Grade Riser Pipe Replacement: 8 단계, 이미지 2/3 Bush Pump Above Grade Riser Pipe Replacement: 8 단계, 이미지 3/3
    • Use a pipe wrench to fully loosen the above grade riser pipe.
  9. Bush Pump Above Grade Riser Pipe Replacement: 9 단계, 이미지 1/3 Bush Pump Above Grade Riser Pipe Replacement: 9 단계, 이미지 2/3 Bush Pump Above Grade Riser Pipe Replacement: 9 단계, 이미지 3/3
    • Lift the slider and riser main pipe.
    • Place a pump rod clamp around the rod, and tighten it securely against the pump rod.
    • Carefully lower the riser main and slider to allow it to rest on the rod clamp.
  10. Bush Pump Above Grade Riser Pipe Replacement: 10 단계, 이미지 1/3 Bush Pump Above Grade Riser Pipe Replacement: 10 단계, 이미지 2/3 Bush Pump Above Grade Riser Pipe Replacement: 10 단계, 이미지 3/3
    • Loosen and remove both the pump rod jam nut and pump rod nut on the top of the slider.
  11. Bush Pump Above Grade Riser Pipe Replacement: 11 단계, 이미지 1/2 Bush Pump Above Grade Riser Pipe Replacement: 11 단계, 이미지 2/2
    • Remove the riser main slider, and inspect it for wear and tear.
    • Set the slider in a sanitary place to prevent contamination.
  12. Bush Pump Above Grade Riser Pipe Replacement, Above Grade Riser Pipe: 12 단계, 이미지 1/3 Bush Pump Above Grade Riser Pipe Replacement, Above Grade Riser Pipe: 12 단계, 이미지 2/3 Bush Pump Above Grade Riser Pipe Replacement, Above Grade Riser Pipe: 12 단계, 이미지 3/3
    • Remove the above grade riser pipe.
    • Firmly screw a T-handle onto the pump rod.
    • If you are replacing the above ground riser main, leave the T-handle attached until you are ready to install the replacement part.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jake Devincenzi
회원 가입일: 04/18/11
117,301 평판
안내서 57개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 422
