소개
This guide will walk you through the procedure to remove the above grade riser pipe. You can then replace it with a new one, or perform any necessary repairs on it.
필요한 것
Remove the above grade riser pipe.
Firmly screw a T-handle onto the pump rod.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
