이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will show you how to remove the cylinder that encases the traveling valve and foot valve.
필요한 것
Remove the above grade riser pipe.
Firmly screw a T-handle onto the pump rod.
Use a pipe wrench to loosen and remove the pump spout.
Place the spout on a clean surface to prevent any contamination.
Place one wrench on the top of one of the pump riser plate bolts.
Place another wrench around the bottom of the bolt.
Pull the wrenches apart to loosen the bolt.
거의 끝나갑니다!
결론
