주요 콘텐츠로 건너뛰기
Bush Pump Head and Handle Replacement
  1. Bush Pump Head and Handle Replacement, Head and Handle: 1 단계, 이미지 1/2 Bush Pump Head and Handle Replacement, Head and Handle: 1 단계, 이미지 2/2
    • Test pump performance by pumping 40 strokes.
    • An effective pump should return at least 10 liters.
  2. Bush Pump Head and Handle Replacement: 2 단계, 이미지 1/2 Bush Pump Head and Handle Replacement: 2 단계, 이미지 2/2
    • Remove the two pins connecting the handle to the slider.
  3. Bush Pump Head and Handle Replacement: 3 단계, 이미지 1/2 Bush Pump Head and Handle Replacement: 3 단계, 이미지 2/2
    • Pull the two lever arms away from the slider.
  4. Bush Pump Head and Handle Replacement: 4 단계, 이미지 1/2 Bush Pump Head and Handle Replacement: 4 단계, 이미지 2/2
    • Lift the two pins attaching the pump frame to the head and handle up, off of the pump frame.
  5. Bush Pump Head and Handle Replacement: 5 단계, 이미지 1/3 Bush Pump Head and Handle Replacement: 5 단계, 이미지 2/3 Bush Pump Head and Handle Replacement: 5 단계, 이미지 3/3
    • Throughout this step, make sure you support the handle and head with at least three hands.
    • Slide the bearing rod out of the head.
    • Inspect the bearing rod and head for any wear or tear.
  6. Bush Pump Head and Handle Replacement: 6 단계, 이미지 1/1
    • Remove the head and handle, and place them on a clean surface to prevent contamination.
결론
Jake Devincenzi
회원 가입일: 04/18/11
117,301 평판
안내서 57개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 164
