소개
Follow this guide to remove and replace or repair the spout on a Bush pump.
필요한 것
Remove the above grade riser pipe.
Firmly screw a T-handle onto the pump rod.
Use a pipe wrench to loosen and remove the pump spout.
Place the spout on a clean surface to prevent any contamination.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
