소개
I will teach you step by step how to dissemble the device and replace the damaged buttons.
부품
No parts specified.
  1. Unscrew the screws on the top side of the device.
    • Unscrew the screws on the top side of the device.
  2. Take the top lid off of the device.
    • Take the top lid off of the device.
  3. Unscrew the screws holding the pink button sheet.
    • Unscrew the screws holding the pink button sheet.
  4. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  5. Remove the button sheet off of the device.
    • Remove the button sheet off of the device.
  6. Examine the button sheet to check for any damages that may prevent the buttons from working.
    • Examine the button sheet to check for any damages that may prevent the buttons from working.
  7. Examine closer at the button sheet for sticks on the opposite side of the buttons.
    • Examine closer at the button sheet for sticks on the opposite side of the buttons.
  8. If the button sheet or button is damaged, you may need to purchase a new button sheet to replace the damaged one.
    • If the button sheet or button is damaged, you may need to purchase a new button sheet to replace the damaged one.
결론
To reassemble, follow these steps in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Chotipong Chamchalaem
회원 가입일: 2012년 09월 26일
80 평판
안내서 2개 작성하였습니다
Cal Poly, Team 7-50, Forte Fall 2012 Cal Poly, Team 7-50, Forte Fall 2012 회원
CPSU-FORTE-F12S7G50
5 회원들
안내서 7개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 170
