소개
¿Tienes un par de zapatos o tal vez un solo zapato con un agujero en la suela? Con esta guía, serás capaz de reparar ese agujero y volver a usar el calzado en vez de comprar un nuevo par.
필요한 것
Limpia la suela con papel absorbente húmedo.
Limpia y seca la suela con papel absorbente antes de comenzar.
¡Ahora puedes volver a caminar!
다른 30명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 10개
Excellent - thank you
I wonder if there is any tip for a sole that has a hole all the way through. I tried something similar like this guid but it was quickly worn out. Maybe if I reinforce with duct tape and build the hole up from inside out, then make it a 2 step progress and do the outside first. Let dry for 2 days and then approach the same from the inside. Hmm such a shame certain brands have weak soles
blackwidow - 답글
Buen dia voy a seguir su recomendacion para reparar mis deportivo GRACIAS
