주요 콘텐츠로 건너뛰기
How to Wipe Samsung Galaxy S4 Data / Factory Reset
동영상 개요
  1. How to Wipe Samsung Galaxy S4 Data / Factory Reset, How to Wipe Samsung Galaxy S4 Data / Factory Reset: 1 단계, 이미지 1/2 How to Wipe Samsung Galaxy S4 Data / Factory Reset, How to Wipe Samsung Galaxy S4 Data / Factory Reset: 1 단계, 이미지 2/2
    • Turn off the phone. Press and hold at the same time Volume UP,Home and Power keys. When you see Galaxy logo release the Power key but continue to hold the Volume Up key and the Home key.
  2. How to Wipe Samsung Galaxy S4 Data / Factory Reset: 2 단계, 이미지 1/3 How to Wipe Samsung Galaxy S4 Data / Factory Reset: 2 단계, 이미지 2/3 How to Wipe Samsung Galaxy S4 Data / Factory Reset: 2 단계, 이미지 3/3
    • Release them when the Android System Recovery screen appears. Use Volume Up/Down keys for navigation and Power On key for OK. Choose "wipe cache partition", "Yes -- delete all user data", "reboot system now".
  3. How to Wipe Samsung Galaxy S4 Data / Factory Reset: 3 단계, 이미지 1/3 How to Wipe Samsung Galaxy S4 Data / Factory Reset: 3 단계, 이미지 2/3 How to Wipe Samsung Galaxy S4 Data / Factory Reset: 3 단계, 이미지 3/3
    • That's all.
    • Did you do it successfully?
결론
This guide does not require resassembly.
다른 283명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,341 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,541개 작성하였습니다
댓글 31개
Here my recommendation is a data eraser named Android Data Eraser, which can erase all Android data including contacts, messages, call history, apps, system setting, photo, video, etc. Indeed, Android Data Eraser worth trusting and it makes the work more effective. What you need is a windows computer. One single click and data deletion finish.
http://www.recover-iphone-android.com/er...
yisdddcbrown - 답글
easy to follow instructions but does not work have done it 3 times now and get to a step which requires to do a factory reset. Phone the automatically switches off and loses connection with program and have to start all over again. Goes round in circles with a factory reset the only result - and you can do that without downloading the program.
maser222e -
why would you bother when you can factory reset in 1 min???
rickialison -
Deleted data from samsung phone are recoverable with Coolmuster Samsung Recovery software. But you need to follow special steps as droid phone`s memory is not accessible easily.
http://www.samsung-recovery.net/
Swolsteedd - 답글
Hi Can the software recover my calendar after I mistakenly did a factory wipe?
Helene Zinberg -
댓글 쓰기
조회 통계:
24 시간 전: 23
7일 전: 159
30일 전: 572
전체 시간: 1,122,972
