소개
¿Tienes problemas para pasar el hilo a través del minúsculo ojo de una aguja? No te preocupes—un enhebrador hará que todo sea más fácil.
Recuerda que esta guía te ayudará a enhebrar solamente hilo fino a través de la aguja, con otros tipos de hilos podrías tener algunas dificultades si el enhebrador no es adecuado.
필요한 것
Sujeta el enhebrador con una mano, y la aguja con la otra.
Introduce el alambre circular del enhebrador en el ojo de la aguja.
Mientras sostienes ambos hilos, tira del enhebrador para que el alambre circular pase de nuevo por el ojo de la aguja.
Una vez que el alambre circular salga completamente del ojo de la aguja, suelta el extremo final del hilo.
Separa con cuidado el enhebrador del hilo restante. Esto hará que el hilo salga del círculo del enhebrador.
다른 71명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
Alberto Gómez님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 18개
thank you for this
it helped me with
sewing project
Swathika E - 답글
For years I have been doing this the hard way. I had no idea what the threader was. I have thrown so many away not knowing what they were. Thank you so much. You've made what i enjoy doing (sewing projects), even more enjoyable.
Shannon B, 01/06/2016
Thank you. My automatic needle threader on sewing machine is off track and I'm not in the mood to locate online how to fix/correct it today. I had plenty of handheld and long neck serger needle threaders in my stash and couldn't figure out how to thread my needle on sewing machine with the long neck threader, but you helped me with that, thanks.
Thank you you are a Life saver!!!!
