주요 콘텐츠로 건너뛰기
Cómo forzar el reinicio del iPhone X
  1. Cómo forzar el reinicio del iPhone X, Cómo forzar el reinicio del iPhone X: 1 단계, 이미지 1/1
    • Presione brevemente el botón para aumentar el volumen (1)
    • Luego presione brevemente el botón para bajar el volumen (2)
    • Tenemos que precionarlos muy brevemente.
  2. Cómo forzar el reinicio del iPhone X: 2 단계, 이미지 1/1
    • Finalmente, mantenga presionado el botón lateral (3) hasta que aparezca el logotipo de Apple y luego suéltelo.
    please what do i do when my iphone X shows Up the Itunes Sign and needs to be Reset ….. And please how do i reset it
    nana dollar - 답글
    I’ve been trying to restart my iPhone X since yesterday night… doing it the way I always do (volume up or down and hold side button) and NOTHING. I just came to look for help online and all the same thing. BUT I found your way… and I got my phone back!!!! It was frozen on the same screens, unresponsive. THANK YOU!!!
    Karina Ardizzi - 답글
    It didn’t work :(. I’m pressing the button….
    Susie Lopez - 답글
    how to know what happen with my iPhone X. dark only could not charge. I did not used a week.
    Bunyavasi Malherbe - 답글
    Nope... still frozen cycle....
    Candy Ogden - 답글
    Yay!! Finally found a simple and easy fix!! and it worked
    Deberah Blair - 답글
    Still pressing didn't show on
    akinyemi taiwo - 답글
    Merci beaucoup
    MBD - 답글
    Merci beaucoup. mais je une question par exemple si je veux regarder une vidéo je n'arrive pas pourquoi?
    MBD - 답글
결론
Has terminado
다른 126명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr es
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
[deleted]
895 평판
안내서 12개 작성하였습니다
댓글 13개
You saved my day. My iphoneX did not respond to anything after connect with the itune. I tried to shut down by holding volume up/down + side button but it didn’t work. So I tried your method and it worked!!! Thank you so much
Satit Jan - 답글
This is a temporary solution whenever my iphone gets unresponsive i used this method but after some time it again starts doing same laggy and unresponsive behaviour
Siraj Munir - 답글
good share. thanks.
MelissaR - 답글
What is the other way?
sa sas - 답글
will it delete all data from my iPhone?
_TR0xuu_ - 답글
No, it will only reboot the operating system. Your data and settings will persist.
Arno Keifl -
Génial. Ca a bien fonctionné même sur un Iphone 12
Emmanuel - 답글
Didn’t work. Now what?
Shawn Leimbach - 답글
It's not working for me, please anymore ideas?
Christiana Linus Ekpo - 답글
Apple logo didn't show on screen,just empty battery sign
May Weather - 답글
hi this literally saved my life thank you so so much!
bk03 - 답글
Face ID has stopped after changing the screen, how to fix
ALKAMBASHE EST - 답글
You have to have a machine that puts the old serial number on the new part so the phone recognizes it. It's called "parts pairing" and it's why Apple sucks. I have seen someone do it with an EEPROM reader/writer but I could not find one for purchase so you would need to go to an Apple-authorized repair tech to have your new parts reserialized.
Sandy Andlow -
댓글 쓰기
조회 통계:
24 시간 전: 42
7일 전: 309
30일 전: 1,460
전체 시간: 347,583
