주요 콘텐츠로 건너뛰기
CASIO CDP-230R Panels Replacement
필요한 것
  1. CASIO CDP-230R Panels Replacement, Panels: 1 단계, 이미지 1/3 CASIO CDP-230R Panels Replacement, Panels: 1 단계, 이미지 2/3 CASIO CDP-230R Panels Replacement, Panels: 1 단계, 이미지 3/3
    • Flip the keyboard upside down, with the keys on a flat surface.
    • Remove the three black 14mm Japanese Industrial Standard (J) head screws using a J1 screwdriver on the top half of the outermost side panel.
  2. CASIO CDP-230R Panels Replacement: 2 단계, 이미지 1/3 CASIO CDP-230R Panels Replacement: 2 단계, 이미지 2/3 CASIO CDP-230R Panels Replacement: 2 단계, 이미지 3/3
    • Use two hands to grab the side panel from both sides.
    • Pull the panel apart from the device one side at a time.
    • There will be popping sounds when you remove this panel.
    • One side panel will not have an orange & white cable connected to it.
  3. CASIO CDP-230R Panels Replacement: 3 단계, 이미지 1/3 CASIO CDP-230R Panels Replacement: 3 단계, 이미지 2/3 CASIO CDP-230R Panels Replacement: 3 단계, 이미지 3/3
    • Remove the three silver 10mm screws with a J1 screwdriver on the bottom half of the innermost side panel of the device.
    • One side panel will not have an orange & white cable running through.
  4. CASIO CDP-230R Panels Replacement: 4 단계, 이미지 1/3 CASIO CDP-230R Panels Replacement: 4 단계, 이미지 2/3 CASIO CDP-230R Panels Replacement: 4 단계, 이미지 3/3
    • Remove the innermost side panel by pinching the top and bottom of the panel and pulling the panel off with both hands.
    • Repeat steps one through four to remove the other side panel of the keyboard.
  5. CASIO CDP-230R Panels Replacement: 5 단계, 이미지 1/3 CASIO CDP-230R Panels Replacement: 5 단계, 이미지 2/3 CASIO CDP-230R Panels Replacement: 5 단계, 이미지 3/3
    • Remove the two black 30 mm J head screws with a J1 screwdriver to remove the long black bar.
    • Remove the four silver 8mm x 2mm J head screws with a J1 screwdriver and the two brackets from the back panel.
    • There will be two screws per bracket.
  6. CASIO CDP-230R Panels Replacement: 6 단계, 이미지 1/3 CASIO CDP-230R Panels Replacement: 6 단계, 이미지 2/3 CASIO CDP-230R Panels Replacement: 6 단계, 이미지 3/3
    • Remove the eight silver 10mm x 1.5mm J head screws with a J1 screwdriver and the square tabs from the back panel.
    • Remove the eight silver 10mm J head screws with a J1 screwdriver underneath the square tabs.
  7. CASIO CDP-230R Panels Replacement: 7 단계, 이미지 1/3 CASIO CDP-230R Panels Replacement: 7 단계, 이미지 2/3 CASIO CDP-230R Panels Replacement: 7 단계, 이미지 3/3
    • Remove the 36 silver 10mm J head screws with a J1 screwdriver from the back panel.
  8. CASIO CDP-230R Panels Replacement: 8 단계, 이미지 1/3 CASIO CDP-230R Panels Replacement: 8 단계, 이미지 2/3 CASIO CDP-230R Panels Replacement: 8 단계, 이미지 3/3
    • Place a hand on the front panel and speakers and carefully flip the keyboard over with the keys facing up.
    • Having a extra pair of hands will be useful.
    • Grab the center of the front panel with two hands and lift to remove panel.
    • Grab the speakers from the sides and lift to remove. Once you have done this for the first speaker, repeat with the second speaker.
결론
Areli Reyes
회원 가입일: 10/01/17
545 평판
안내서 4개 작성하였습니다
Cal Poly, Team S4-G2, Livingston Fall 2017 Cal Poly, Team S4-G2, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S4G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 12
전체 시간: 888
