주요 콘텐츠로 건너뛰기
CASIO fx-570MS Battery Replacement
필요한 것
  1. CASIO fx-570MS Battery Replacement, charger: 1 단계, 이미지 2개 중 1개 CASIO fx-570MS Battery Replacement, charger: 1 단계, 이미지 2개 중 2개
    • Flip the calculator over so the bottom is facing upwards.
  2. CASIO fx-570MS Battery Replacement: 2 단계, 이미지 3개 중 1개 CASIO fx-570MS Battery Replacement: 2 단계, 이미지 3개 중 2개 CASIO fx-570MS Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the screw from the battery hatch on the top-right corner using a 1.5 mm slotted screwdriver.
    • Remove the battery hatch.
  3. CASIO fx-570MS Battery Replacement: 3 단계, 이미지 3개 중 1개 CASIO fx-570MS Battery Replacement: 3 단계, 이미지 3개 중 2개 CASIO fx-570MS Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Insert a spudger into the dent to the left of the battery until it hits the bottom of the panel board.
    • To create leverage, gently push the spudger towards the bottom of the battery (pushing your hand downwards and towards the back cover if necessary) to lift the battery out of its compartment.
    • Caution: Be careful to not rupture the battery or damage the panel board.
  4. CASIO fx-570MS Battery Replacement: 4 단계, 이미지 3개 중 1개 CASIO fx-570MS Battery Replacement: 4 단계, 이미지 3개 중 2개 CASIO fx-570MS Battery Replacement: 4 단계, 이미지 3개 중 3개
    • When you insert the new battery into the battery compartment, it should remain bulged upwards on the side towards the dent.
    • Make sure the flat side of the battery is facing upwards.
    • To finish inserting the new battery into the battery compartment, gently press the bulged corner with your finger until it slides into place.
  5. CASIO fx-570MS Battery Replacement: 5 단계, 이미지 2개 중 1개 CASIO fx-570MS Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Close the plastic hatch and secure the screw.
  6. CASIO fx-570MS Battery Replacement: 6 단계, 이미지 2개 중 1개 CASIO fx-570MS Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Flip the calculator on its back and press the 'ON' button to power it up.
    • A zero will appear on the bottom right corner of the LED display.
결론
Your beloved CASIO fx-570MS Scientific Calculator is good to go for another few years.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Saquib Ahmed
회원 가입일: 09/20/20
205 평판
안내서 1개를 작성함
York University, Team S3-G40, Melo-Thaiss Fall 2020 York University, Team S3-G40, Melo-Thaiss Fall 2020 회원
YORK-MELO-THAISS-F20S3G40
1 회원
안내서 5개를 작성함
1가이드 댓글
How much does the battery cost?
Tamanna - 답글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 76
지난 30일: 477
전체 시간: 55,467
